Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - update does not apply to your system error when the system is corr
Old 02-06-2008   #1 (permalink)
Rogueninja
I am trying to download an update that removes the "Driver has stopped
working and Recovered" error but when I try to run the update (I have a
Compaq T2080 Notebook with Windows Vista Home Premium) it says that it
doesn't apply to my system. I downloaded the one for 32bit systems, so isn't
that the right update? Any help would be greatly appreciated.
Old 02-06-2008   #2 (permalink)
helpherb
RE: update does not apply to your system error when the system is corr
Hard to say without knowing which update you are trying to install. Go here
http://support.microsoft.com/default.aspx/ph/11732 and enter the update
number and it will explain the applicability of the update.
For example, the error message you mention (or one similar) occurs on
systems with nVidia graphics cards and older drivers. If you try to install
this and don't have and nVidia card, it won't install.
Old 02-06-2008   #3 (permalink)
Rogueninja
Sorry, it was the KB940105-x86 update.
Old 02-07-2008   #4 (permalink)
romanom
Check under installed updates to make sure it's not already installed. Also,
not every update is for every system, many updates are specific to certain
software/drivers and/or components.
For installed update
Control Panel > (left upper corner) View installed updates
Check the list for KB940105 (FYI: didn't apply to my system either)
http://support.microsoft.com/Default.aspx?kbid=940105
the update does not apply to your system Vista General
the update does not apply to your system Vista installation & setup
"The update does not apply to your system" with Vista Business x86 PowerShell
Update does not apply to your system Virtual Server
the update does not apply to your system PowerShell
