| | Strange characters appear in DOS window using PING command Hi I have suffered some sort of system failure on my XPpro machine - the blue screen of death! It would get to the login screen, go blue then reboot. I first removed and swapped memory and video cards etc, to no avail. I then tried a disk check from safe mode with both options ticked, reboot and let it go. Still same problem when starting normally. I have a RAID 0 (mirror only) and had to remove the IDE card and place one drive directly into the motherboard to re-install windows over itself. It seems to be okay (mostly!) once again and when I am happy with this repair I will re-establish the RAID 0. In testing connectivity, I pinged 127.0.0.1 from a command promt and this worked except that it displayed "Pinging oÿ with 32 bytes of data". (the "o" is in superscript and my machine is named HOME1.) It gives the same result if I ping my Vista machine on 192.168.0.5 or by its name. I have done a full disk check since recovering and the machine seems to be doing everything else properly. I don't get it as this machine has been rock-solid stable and reliable for at least 2 years. So my questions are: Will I have to perform a full installation and blow away all of my setup that has many useful programs and utilities installed? Is there a way of correcting this anomaly without taking such a drastic measure? Should I care that I am getting wierd characters in a DOS prompt? Many thanks in advance Darth_Lager |
| | Re: Strange characters appear in DOS window using PING command neat...right click on the top bar of a command window and choose PROPERTIES. Go to the FONT window....what is the selected font? "Darth_Lager" <Darth_Lager@xxxxxx> wrote in message news:3E7FB95E-0862-497F-ACD5-ABA2E27266AC@xxxxxx Quote: > Hi > I have suffered some sort of system failure on my XPpro machine - the blue > screen of death! It would get to the login screen, go blue then reboot. I > first removed and swapped memory and video cards etc, to no avail. I then > tried a disk check from safe mode with both options ticked, reboot and let > it > go. Still same problem when starting normally. I have a RAID 0 (mirror > only) > and had to remove the IDE card and place one drive directly into the > motherboard to re-install windows over itself. It seems to be okay > (mostly!) > once again and when I am happy with this repair I will re-establish the > RAID > 0. > > In testing connectivity, I pinged 127.0.0.1 from a command promt and this > worked except that it displayed "Pinging oÿ with 32 bytes of data". (the > "o" > is in superscript and my machine is named HOME1.) It gives the same result > if > I ping my Vista machine on 192.168.0.5 or by its name. I have done a full > disk check since recovering and the machine seems to be doing everything > else > properly. > > I don't get it as this machine has been rock-solid stable and reliable for > at least 2 years. > > So my questions are: Will I have to perform a full installation and blow > away all of my setup that has many useful programs and utilities > installed? > Is there a way of correcting this anomaly without taking such a drastic > measure? Should I care that I am getting wierd characters in a DOS prompt? > > Many thanks in advance > Darth_Lager |
| Strange Characters in Emails | Live Mail | |||
| Strange Characters Appearing in Emails | Live Mail | |||
| Ping command | Network & Sharing | |||
| command line maximum number of characters | Vista General | |||
| Strange characters in the admin account | Vista General | |||
