| | Stuck in Safe Mode in Normal Startup mode need help! I don't know when this happened as It could have been from the begining since installing Vista, but when I opened my System Config. utility I noticed an issue that is bothering me. It seems that my PC is starting up as if it's normal in Selective start up mode only. It i tick on Normal Startup the boot tap will automatical tick into Safe mode. If i un-tick the safe mode option in the boot tab than it goes back to selective start. How can i fix this! I would like to start my pc in Normal without going into safe mode. I hear It's not safe to have been always starting in seclective mode. So there is a problem here and I can't find an answer. please help! Thank you! |
| | RE: Stuck in Safe Mode in Normal Startup mode need help! Mike,there is no problem with it starting in Selective Mode. I always have my XP and Vista doing it. All selective mode means is that you, or a Tech, has taken some program/s out from starting at startup. Also, you might not want to run particular programs at startup. A lot of people take Programs out from startup to make it start up quicker! If you have Games, whatever; you don't need to start them at startup; just double-click the desktop icon. Cheers! -- Mick Murphy - Qld - Australia "Mike" wrote: Quote: > I don't know when this happened as It could have been from the begining since > installing Vista, but when I opened my System Config. utility I noticed an > issue that is bothering me. > It seems that my PC is starting up as if it's normal in Selective start up > mode only. > It i tick on Normal Startup the boot tap will automatical tick into Safe mode. > > If i un-tick the safe mode option in the boot tab than it goes back to > selective start. > How can i fix this! I would like to start my pc in Normal without going into > safe mode. > I hear It's not safe to have been always starting in seclective mode. > So there is a problem here and I can't find an answer. > please help! > > Thank you! |
| Vista HP - Normal Boot OK, Can't access Safe Mode | Vista General | |||
| MSCONFIG Boot - Stuck in Safe Mode or Selective Startup | Vista performance & maintenance | |||
| vista only boot to safe mode but not normal mode | Vista General | |||
| Unable to boot in Safe or Normal mode | Vista General | |||
| Stuck in Safe Mode | Vista performance & maintenance | |||
