Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Screen Saver Problems
Old 03-09-2008   #1 (permalink)
bluecrystal99
My screen saver will not work. After reading through some questions and
responses I have figured out that it is my wireless mouse causing the
problem. To confirm I unplugged the mouse and my screen saver worked. I have
windows vista and I installed and update.
Is there anything else I can do to correct this problem?
Old 03-10-2008   #2 (permalink)
Hank
Re: Screen Saver Problems
Use Google and type in " screensaver wont activate in vista " without the
quotes go to the first website about 1/2 down the second response will send
you to a Microsoft website go there and follow the resolve problem it will
take you to a vista update page look for something that refers to a user HID
device ( cant remember exact wording ) and that will fix it, I use it all
the time and it works. This is a known MS problem, hope they fixed it in
Vista XP1
Hank
"bluecrystal99" <bluecrystal99@xxxxxx> wrote in message
news:8F65A2C3-66CD-4B29-9E61-AB00A828C347@xxxxxx
> have
Mouse/screen saver problems Vista General
Problems with returning from screen saver Vista performance & maintenance
Screen Saver -problems with pictures setting Vista General
Screen saver problems Vista General
Screen Saver Problems Vista performance & maintenance
