Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Cursor Problem
Old 03-10-2008   #1 (permalink)
kimmy707
Cursor Problem
The circle (that used to be the hourglass) just keeps popping up near my
cursor, even when I'm not doing anything, and it's very annoying. Can anyone
tell me what the problem might be? thanks!!
Old 03-11-2008   #2 (permalink)
Jeff Smith [MSFT]
RE: Cursor Problem
It means that some background program is doing a lot of work. It could be an
update downloading, or routine system tuning, antivirus scanning, or just
about anything.
Next time it happens, open the Start menu, type in perfmon.exe, and press
Enter. The Performance Monitor will show you which programs are using up
your processor, memory, or hard disk bandwidth.
Old 03-20-2008   #3 (permalink)
bsrl0087
RE: Cursor Problem
I have exactly the same problem. Also my screen saver does not activate now.
The screen goes blank. Any help for us would be appreciated
Old 03-20-2008   #4 (permalink)
vista home premium 32bit
Re: Cursor Problem
Quote  Quote: Originally Posted by bsrl0087 View Post
The cursor question has been answered. Maybe I'll chip in on the screensaver part. Go to the screensaver window and see what is selected, and at the same time check the Preview to see if it is working.
Cursor problem Vista General
cursor keyboard touch pad very sensitive and cursor bounces around Vista General
crazy cursor - cursor keeps bouncing back form certain clickable a Vista performance & maintenance
Problem with cursor Vista performance & maintenance
