| | NOVICE NEEDS HELP packardbell easynote MZ-36 Windows Vista Home Premium It started when my dvd/cd rom started to play up,I looked and found it in device manager and noticed a storage controller also not working. I tried to update the drivers but was unable. I tried to download anything but keep getting "The directory name is not valid" and on others a reference to i18nisolang.MSC.dll.My computer is only 6 mth old and was expensive TO me,does anyone have some help out there,I would be eternaly grateful,thing is,Im getting worried because I cant download at all and my security needs re-newing. thanks. |
| | Re: NOVICE NEEDS HELP Hi, You may simply need to reseat the cabling in the drive tower. It may have come loose. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org My thoughts http://rick-mvp.blogspot.com "craig mcculloch" <craigmcculloch@xxxxxx> wrote in message news:61A76924-9FE4-441C-A762-C7197F569BEA@xxxxxx Quote: > packardbell easynote MZ-36 > Windows Vista Home Premium > > It started when my dvd/cd rom started to play up,I looked and found it in > device manager > and noticed a storage controller also not working. I tried to update the > drivers but was unable. I tried to download anything but keep getting "The > directory name is not valid" and on others a reference to > i18nisolang.MSC.dll.My computer is only 6 mth old and was expensive TO > me,does anyone have some help out there,I would be eternaly grateful,thing > is,Im getting worried because I cant download at all and my security needs > re-newing. > thanks. |
| Novice needs help | Vista General | |||
| xp to vista - novice | Vista installation & setup | |||
| VPN novice | Vista General | |||
| Vista is not for the novice | Vista General | |||
| Vista Novice... | Vista installation & setup | |||
