| | Power meter icon After installing Vista SP1 today, my power meter icon is gone from the notification area. I've tried a number of things but can't get it back. Can anyone help? |
| Windows 7 RC | Re: Power meter icon I hope this helps. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Power meter icon The Power icon will only be available (not grayed out) if your laptop is on battery power, or computer is plugged into a backup power UPS box. If this is true, then check in Method One for how to turn it back on as Joe's post suggested. Notification Area - System Icons Shawn |
| | Re: Power meter icon Thanks Joe, that did the trick. I looked at that several times and just overlooked it. Thanks again. ".Joe" wrote: Quote: > > A330nrt;653222 Wrote: Quote: > > After installing Vista SP1 today, my power meter icon is gone from the > > notification area. I've tried a number of things but can't get it back. > > Can > > anyone help? > As far as I know (for laptops anyway), you can right click on the > system tray, click properties, then click the power box, click apply and > ok. That should take care of it. > > I hope this helps. > > > -- > .Joe > > _[image: > http://uswave.net/vistax64/joetmvx64.png] (\"http://www.vistax64.com/index.php?referrerid=17621\")_ > _*::Click_here_for_the_Vista_Forums::* (\"http://www.vistax64.com/index.php?referrerid=17621\")_ > _Geekbench_Score:_4050 (\"http://browse.geekbench.ca/geekbench2/view/42901\")_ > _CPU-Z_Verified (\"http://valid.x86-secret.com/show_oc.php?id=323179\")_ > |
| | Re: Power meter icon Since yesterday I noticed I have no power icon in the notification area -- no AC power or battery. I followed your directions also, .Joe, but after clicking on Properties, I see no "power box". I'm using Win XP (SP3) on HP Compaq Presario laptop. ~Grev ".Joe" wrote: Quote: > > A330nrt;653222 Wrote: Quote: > > After installing Vista SP1 today, my power meter icon is gone from the > > notification area. I've tried a number of things but can't get it back. > > Can > > anyone help? > As far as I know (for laptops anyway), you can right click on the > system tray, click properties, then click the power box, click apply and > ok. That should take care of it. > > I hope this helps. > > > -- > .Joe > > _[image: > http://uswave.net/vistax64/joetmvx64.png] (\"http://www.vistax64.com/index.php?referrerid=17621\")_ > _*::Click_here_for_the_Vista_Forums::* (\"http://www.vistax64.com/index.php?referrerid=17621\")_ > _Geekbench_Score:_4050 (\"http://browse.geekbench.ca/geekbench2/view/42901\")_ > _CPU-Z_Verified (\"http://valid.x86-secret.com/show_oc.php?id=323179\")_ > |
| | #6 (permalink) |
| | Re: Power meter icon I just want to add that my power icon is back! In another thread "system tray notification icons missing and disable", the poster Ricardo Montabone suggested "just log out and log back in". I did; and it worked. ~Grev "Grev" wrote: Quote: > Since yesterday I noticed I have no power icon in the notification area -- no > AC power or battery. I followed your directions also, .Joe, but after > clicking on Properties, I see no "power box". I'm using Win XP (SP3) on HP > Compaq Presario laptop. > ~Grev > > ".Joe" wrote: > Quote: > > > > A330nrt;653222 Wrote: Quote: > > > After installing Vista SP1 today, my power meter icon is gone from the > > > notification area. I've tried a number of things but can't get it back. > > > Can > > > anyone help? > > As far as I know (for laptops anyway), you can right click on the > > system tray, click properties, then click the power box, click apply and > > ok. That should take care of it. > > > > I hope this helps. > > > > > > -- > > .Joe > > > > _[image: > > http://uswave.net/vistax64/joetmvx64.png] (\"http://www.vistax64.com/index.php?referrerid=17621\")_ > > _*::Click_here_for_the_Vista_Forums::* (\"http://www.vistax64.com/index.php?referrerid=17621\")_ > > _Geekbench_Score:_4050 (\"http://browse.geekbench.ca/geekbench2/view/42901\")_ > > _CPU-Z_Verified (\"http://valid.x86-secret.com/show_oc.php?id=323179\")_ > > |
| Taskbar issues - missing power meter, network icon, and sound icon | Vista General | |||
| RE: No power icon | Vista General | |||
| Changing power plans shown on battery meter | Vista performance & maintenance | |||
| Power icon | Vista performance & maintenance | |||
