Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - 0x80041013 Provider Load Failure on restore point script
Old 03-24-2008   #1 (permalink)
Vista Home Premium 64 bit SP1
I'm trying to create a restore point in 32 bit Vista Home Premium using a
VBScript. I can create a Restore Point the ordinary way, but using a script
generates 0x80041013 Provider Load Failure.
Can anyone tell me the dependencies of wscript? afaik I have the necessary services running. wbem folder is in the path environment variable.
Alternatively is there a programmatic way to create a restore point that doesn't rely on wscript? I'm just looking for something to create a restore point without having to go through the GUI.
Old 07-04-2008   #2 (permalink)
Ultimate
Re: 0x80041013 Provider Load Failure on restore point script
I know this is a Vista forum but I am in the process of resolving as similar issue with XP Pro SP2.
If I find anything I will try to remember to post it here.
Good luck to us both.
Here is my script
option explicit
Dim WSHShell, SRP, CSRP, description, result
Set WSHShell = CreateObject("WScript.Shell")
description="Service Restore Point"
set SRP = getobject("winmgmts:\\.\root\default:Systemrestore")
CSRP = SRP.createrestorepoint (description, 0, 100)
result= MsgBox("Restore Point Created Successfully!")
System Restore Task - Change Automatic Restore Point Schedule Tutorials
RSOP Planning mode - Provider load failure. VB Script
System Restore error (create restore point), event ID: 8193 Vista General
System restore hasn't held a restore point since I installed Vista Vista General
Restore point filling drive to point of no free space Vista performance & maintenance
