Vista 64: Please help me get rid of mobsync.exe and wmplayer.exe always running in the background
  1. #1
    Georg Guest
    I looked around for some time, but i did not get any usable answer.
    I am running Vista Ultima 64 and i ask fior advice applying to Vista and NOT
    2000.
    The Problem:
    using process explorer and tasskmanager i constantly see mobsync.exe running
    as well as wmplayer, invisible in the background.
    It looks like they index something.
    I found out that this must have something to do with either offline files,
    sync center or mediaplayer sharing, maybe also related to the USB sticks i
    have in my PC.
    But no matter what tips and tricks i apply, no matter what i set, what
    service i disable...i cannot get rid of those constantly starting. I dont
    what triggers them!
    I want that mobsync.exe as well as wmplayer NEVER appear in the list of
    running tasks anymore, no "indexing" of my drives, nothing.
    Thank you!
    G.
    Vista U 64
  2. #2
    Jack \(MVP-Networking\). Guest
    Re: Vista 64: Please help me get rid of mobsync.exe and wmplayer.exe always running in the background
    Hi
    Processes like this can be invoked directly, or can be a result of running
    applications that you do need and use these processes.
    If you do not want Indexing then disable the Indexing.
    Otherwise you can use these two free applications (Startup & Process
    Explorer) to snoop around and disable in need applications and startups.
    http://www.ezlan.net/infestation.html#startup
    Jack (MVP-Networking).
    "Georg" <gwrauh1@xxxxxx> wrote in message
    news:%23D8BwDojIHA.4664@xxxxxx
    > NOT 2000.
    > The Problem:
    > running as well as wmplayer, invisible in the background.
    > have in my PC.
    > what triggers them!
    > Thank you!
    > G.
    > Vista U 64
    > 4GB
  3. #3
    Michael Bednarek Guest
    On Tue, 25 Mar 2008 15:06:35 +0100, "Georg" <gwrauh1@xxxxxx> wrote in
    microsoft.public.windows.vista.general,
    [microsoft.public.windows.vista.networking_sharing,
    microsoft.public.windows.vista.performance_maintenance]:
    >2000.
    >The Problem:
    [snip]
    I don't know about your problem with wmplayer (it's not constantly
    running here (Windows 6, aka Vista [Business]), but maybe that's because
    I've never run wmplayer), but I managed to extinguish mobsync by
    stopping the service "Offline Files" (CscService) and setting its
    "Startup type" to Manual.
    HTH
    Michael Bednarek http://mbednarek.com/ "POST NO BILLS"
Vista 64: Please help me get rid of mobsync.exe and wmplayer.exe always running in the background problems?
wmplayer runs in background at startup tahoekid General Discussion 0 28 Mar 2009
Vista 64: Please help me get rid of mobsync.exe and wmplayer.exe always running in the background Georg Vista General 5 17 Oct 2008
Vista 64: Please help me get rid of mobsync.exe and wmplayer.exe always running in the background Georg Vista networking & sharing 2 03 Apr 2008
How do I check what is running in the background with Vista Ultimate? TIA!!! AnyWhere@USA.com Vista General 5 09 May 2007
so many DfrgNtfs.exe running background once kick off the defragment in vista Yinghe Chen Vista General 6 11 Jan 2007
