Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - a labeled readyboost USB flasdrive "not recognize unknown" in Vist
Old 04-05-2008   #1 (permalink)
GT
my usb 2.0 and my labeled readyboost usb flasdrive 2.0 is working properly
but I see the Event viewer log at random days that its unknown "displayed
below". My USB Flash drive is properly connected to the USB fulltime and
never get remove. Readyboost is working looking at the activity light.
Source: Readyboost
EventID: 1002
User: System
opcode: Info
The device (Unknown Unknown) will not be used for a ReadyBoost cache because
it is not attached to a supported interface.
Old 04-05-2008   #2 (permalink)
Windows 7 RC
Re: a labeled readyboost USB flasdrive "not recognize unknown" in Vist
Quote  Quote: Originally Posted by GT View Post
Source: Readyboost
EventID: 1002
User: System
opcode: Info
You should be ok if the USB drive is working ok. Vista does a lot of reporting, sometimes I think more than it needs to.
Vista "Complete PC Restore" doesn't recognize backup files. Vista General
Vist Mail "Steals" from my AT&T Inbox Vista mail
Seeking a safe workaround for "An unknown program wants access to your computer" System Security
Need list of ReadyBoost "certified" USB Flash drives Vista General
how to recognize "unknown device" Vista hardware & devices
