Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Automatic power plan selection
Old 04-12-2008   #1 (permalink)
JoeVentola
Is there a way to get my Toshiba laptop to automatically select Power Saver
plan when running on batteries, and High Performance (or some other plan)
when plugged in?
Old 04-13-2008   #2 (permalink)
Home premium 32 bit, SP1
Re: Automatic power plan selection
Quote  Quote: Originally Posted by JoeVentola View Post
when plugged in?
Hello, Joe. Great idea! Unfortunately no.
Solved Power Options Corrupt (power plan unavailable) General Discussion
Power Plan Controversy General Discussion
Automatic power plan change? General Discussion
Power Plan?? Vista General
Disable Power Plan Vista performance & maintenance
