Vista Home Premium not shutdown
  1. #1
    SEMO Guest
    Hi, I have a problem in vista home premium, every time i'm trying to
    shutdown, the computer restarts. That means I have to shut it down myself
    from the power button.
    Could any body tell me how I can solve the problem ?
    Thnx,
  2. #2
    SG Guest
    Re: Vista Home Premium not shutdown
    Do a Google search for.....
    vista reboots when trying to shutdown
    It is very dangerous to do what you have been doing. When you cut the power
    off like that anything in memory try's to write back to the hard drive and
    it's just a matter of time when something will become corrupt. It can leave
    your Windows totally crashed and you would have to format and start all
    over. Unless you "have" to turn it off you would be better off leaving it on
    until you find and fix your problem.
    All the best,
    SG
    Is your computer system ready for Vista?
    https://winqual.microsoft.com/hcl/
    "SEMO" <SEMO@xxxxxx> wrote in message
    newsC9B1888-2B39-4857-B947-AC5C170A3E15@xxxxxx
    > Thnx,
  3. #3
    Banned
    Canada
    Windows 7, Home Premium 64-bit, SP1. Vista Home Premium 32-bit SP2.
    Local Time: 04:56 AM
    canada ca ontario
    Quote Originally Posted by SEMO View Post
    Thnx,
    Hello SEMO,
    What kind of computer do you have ? A desktop or laptop ?
    Other than using the power button, how did you Usually shut the computer down ?
    What kind of power settings do you use ?
    If you can give us some relevent circumstances, it might help us visualize your problem.
Vista Home Premium not shutdown problems?
hangs on restart and shutdown - vista home premium upgrade quartet1977 Vista General 9 15 Apr 2009
Vista Home Premium/SnagIt 9.1.0 shutdown problem cured in 9.1.1 Doug Vista General 0 15 Feb 2009
Remote Access from Vista Home Premium to Vista Home Premium and XP Home Edition cmacandrew Network & Sharing 2 26 Mar 2008
Vista Home Premium Freezes on startup and then won't shutdown Jon. Vista General 1 29 Jan 2008
Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H rrdToledo Vista General 6 24 Sep 2007
