| | Power Management no longer allowing me to change display brightnes I'm on a Toshiba Satellite that's worked fairly well except for a few self-repaired hiccups. However, about a week ago my power management plans suddenly stopped working. I can switch from different plans that change how quickly my display turns off, but my screen has been stuck at the lowest brightness possible for a while now. It has nothing to do with the plans themselves, I've restored all to their default settings and still no change in brightness when I switch between all of them. The little slider to adjust brightness simply does not appear anymore. I can't find what exactly it is that's malfunctioning to reinstall, as no power management driver appeared on my disk from Toshiba. Can anyone provide an explanation or perhaps a link to repair this? |
| Home premium 32 bit, SP1 | Re: Power Management no longer allowing me to change display brightnes I'm on a Toshiba Satellite that's worked fairly well except for a few self-repaired hiccups. However, about a week ago my power management plans suddenly stopped working. I can switch from different plans that change how quickly my display turns off, but my screen has been stuck at the lowest brightness possible for a while now. It has nothing to do with the plans themselves, I've restored all to their default settings and still no change in brightness when I switch between all of them. The little slider to adjust brightness simply does not appear anymore. I can't find what exactly it is that's malfunctioning to reinstall, as no power management driver appeared on my disk from Toshiba. Can anyone provide an explanation or perhaps a link to repair this? |
| | Re: Power Management no longer allowing me to change display brigh No, unfortunately by the time I realized that a simple shut down and restart wouldn't solve the problem, my computer had overwritten the restore points before the problem happened. "t-4-2" wrote: Quote: > > Shiroinohi;686891 Wrote: Quote: > > I'm on a Toshiba Satellite that's worked fairly well except for a few > > self-repaired hiccups. However, about a week ago my power management > > plans > > suddenly stopped working. I can switch from different plans that change > > how > > quickly my display turns off, but my screen has been stuck at the > > lowest > > brightness possible for a while now. It has nothing to do with the > > plans > > themselves, I've restored all to their default settings and still no > > change > > in brightness when I switch between all of them. The little slider to > > adjust > > brightness simply does not appear anymore. I can't find what exactly it > > is > > that's malfunctioning to reinstall, as no power management driver > > appeared on > > my disk from Toshiba. Can anyone provide an explanation or perhaps a > > link to > > repair this? > prior to the problem(s) arose ? > > > -- > t-4-2 > |
| Home premium 32 bit, SP1 | Re: Power Management no longer allowing me to change display brigh No, unfortunately by the time I realized that a simple shut down and restart wouldn't solve the problem, my computer had overwritten the restore points before the problem happened. "t-4-2" wrote: Quote: > > Shiroinohi;686891 Wrote: > Hello, can you not just simply do a system restore, choosing a date > prior to the problem(s) arose ? > > > -- > t-4-2 > You said the little slider that adjusts brightness is gone. Does that mean if you were on Power Options window and you clicked Adjust Display Brightness ( left panel), the next window that popped up would not have the sliders shown ?? |
| | Re: Power Management no longer allowing me to change display brigh Adjust Display Brightness no longer appears on the left hand menu. Before it did, but now I have no way of adjusting the brightness. "t-4-2" wrote: Quote: > > Shiroinohi;687082 Wrote: Quote: > > No, unfortunately by the time I realized that a simple shut down and > > restart > > wouldn't solve the problem, my computer had overwritten the restore > > points > > before the problem happened. > > > > "t-4-2" wrote: Quote: > > > > > > > > > > > > > Shiroinohi;686891 Wrote: > > > > Hello, can you not just simply do a system restore, choosing a date > > > > prior to the problem(s) arose ? > > > > > > > > > > > > -- > > > > t-4-2 > > > > > > > You said the little slider that adjusts brightness is gone. Does that > mean if you were on Power Options window and you clicked Adjust Display > Brightness ( left panel), the next window that popped up would not have > the sliders shown ?? > > > -- > t-4-2 > |
| | #6 (permalink) |
| Home premium 32 bit, SP1 | Re: Power Management no longer allowing me to change display brigh Adjust Display Brightness no longer appears on the left hand menu. Before it did, but now I have no way of adjusting the brightness. "t-4-2" wrote: Quote: > > Shiroinohi;687082 Wrote: > Hello Shiroinohi, > You said the little slider that adjusts brightness is gone. Does that > mean if you were on Power Options window and you clicked Adjust Display > Brightness ( left panel), the next window that popped up would not have > the sliders shown ?? > > > -- > t-4-2 > |
| | #7 (permalink) |
| | Re: Power Management no longer allowing me to change display brigh It might have been SP1, though I don't really remember when I installed it. How would I go about uninstalling in order to check? "t-4-2" wrote: Quote: > > Shiroinohi;687488 Wrote: Quote: > > Adjust Display Brightness no longer appears on the left hand menu. > > Before it > > did, but now I have no way of adjusting the brightness. > > > > "t-4-2" wrote: Quote: > > > > > > > > > > > > > Shiroinohi;687082 Wrote: > > > > Hello Shiroinohi, > > > > You said the little slider that adjusts brightness is gone. Does that > > > > mean if you were on Power Options window and you clicked Adjust > > > Display > > > > Brightness ( left panel), the next window that popped up would not > > > have > > > > the sliders shown ?? > > > > > > > > > > > > -- > > > > t-4-2 > > > > > > > guess, it happened after you installed the SP1 ? If so, I can only > suggest ,and a lot of people will yell at me, perhaps you would consider > un-installed it. It's like i-phone came out, why do we Have to have it > ?? Your computer life was pretty stable before, isn't it ? > > > -- > t-4-2 > |
| | #8 (permalink) |
| Home premium 32 bit, SP1 | Re: Power Management no longer allowing me to change display brigh It might have been SP1, though I don't really remember when I installed it. How would I go about uninstalling in order to check? "t-4-2" wrote: Quote: > > Shiroinohi;687488 Wrote: > I'm out of idea, as I'm not a "geek", figure of speech. Just one wild > guess, it happened after you installed the SP1 ? If so, I can only > suggest ,and a lot of people will yell at me, perhaps you would consider > un-installed it. It's like i-phone came out, why do we Have to have it > ?? Your computer life was pretty stable before, isn't it ? > > > -- > t-4-2 > If you "don't remember it", then you have NOT installed SP1. Sorry, I'm out of idea. |
| | #9 (permalink) |
| | RE: Power Management no longer allowing me to change display brightnes Have you tried to go to http://www.csd.toshiba.com/cgi-bin/t...su_sc_home.jsp , select your model and download the "Toshiba Value Added Package" and (re) install it? It has the power management features. This might help, hopefully ![]() |
| | #10 (permalink) |
| | RE: Power Management no longer allowing me to change display brigh Just uninstalled and reinstalled the package, and still no change, thanks though. "moondawg" wrote: Quote: > Have you tried to go to > http://www.csd.toshiba.com/cgi-bin/t...su_sc_home.jsp , select your model > and download the "Toshiba Value Added Package" and (re) install it? It has > the power management features. This might help, hopefully ![]() |
| power management | General Discussion | |||
| Power Management/Power Options in Vista | Vista General | |||
| Power management | Vista networking & sharing | |||
| Power Management | Vista General | |||
| Power Management | Vista hardware & devices | |||
