Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Recycle Bin Problem
Old 04-20-2008   #1 (permalink)
Kate
Recycle Bin Problem
I have not been able to drag and drop files, pictures or folders into my
recycle bin lately with out having to wait over a minute for it to get
there.. I don't know what happened but it use to work fine. It now takes over
a minute to get from the desktp to the recycl bin, and during that minute I
can not use anything else on my computer. I f anyone has any suggestion I
would appreciate it very much as I use this every day.
Thanks,
Kate Galway
Old 04-20-2008   #2 (permalink)
Mick Murphy
RE: Recycle Bin Problem
Just Right-click> Delete the file or folder!
Mick Murphy - Qld - Australia
> Thanks,
> Kate Galway
Old 04-20-2008   #3 (permalink)
Re: Recycle Bin Problem
Quote  Quote: Originally Posted by Mick Murphy View Post
> Thanks,
> Kate Galway
Hi Kate,
In addition to Mick Murphy's post:
If this still does not help, then you may have a corrupted Recycle Bin. This tutorial will show you how to reset the Recycle Bin.
Recycle Bin Corrupted - Cannot Delete File or Folder
Recycle bin problem Vista General
Recycle Bin Problem Vista General
recycle bin problem Vista General
Recycle Bin problem. Vista General
