Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Problems with display when opening pdf in Vista
Old 04-28-2008   #1 (permalink)
hamstergal
Hello! I haven't seen this question anywhere, but I do hope that there is
someone who can help me with this problem.
Whenever I open a .pdf file, whether in Acrobat or within a web browser, my
computer suddenly goes into low-color (8-bit) mode, and I have to go to
personalization/display settings to correct it. I have the most recent
version of Acrobat, and have tried uninstalling and reinstalling it, but this
still happens every time I open a .pdf!
Is there anything I can do to stop this, and prevent it from happening in
the future? It's extremely frustrating!
Thanks!
Old 04-29-2008   #2 (permalink)
Bob J
RE: Problems with display when opening pdf in Vista
I had similar problems with Adobe and could not find a remedy, eventually
started using a program called 'Foxit Reader" and completely uninstalled
'Adobe" now use 'Foxit" with no problems and it is not as bloated as 'Adobe"
Regards
Bob J
If advise given from anyone, solves problem or not, or if solved from
another source,post back & let us know.
Then we all benefit.
> Thanks!
Old 04-30-2008   #3 (permalink)
gerryf
Re: Problems with display when opening pdf in Vista
> Thanks!
Navigate to C:\Program Files\Adobe\Reader 8.0\Reader, right click
AcroRd32.exe and choose PROPERTIES...check the compatibility tab and
clear any settings
Old 04-30-2008   #4 (permalink)
hamstergal
Bob--
Thanks for the tip! I did wind up fixing Acrobat, but if I find there are
any more problems, I will try Foxit. It's sometimes hard to find alternatives
for widely-used software.
> Regards
> Bob J
Problems opening word documents on vista Microsoft Office
problems opening vista windows mail Vista mail
Access 2003 problems opening under Vista Business... Vista security
problems opening programs with vista Vista performance & maintenance
Display settings Window opening on startup Vista hardware & devices
