| Guest | problems with volume shadow copy service Hi I recently tried to create a restore point and it failed due to the volume shadow copy not working error 0x81000202 but subsequently on using vssadmin i see that it is not installed on my computer anymore. I have vista home premium which was installed on a new pc 5 months ago. This is a problem as i will not be able to intall vista sp1 on my computer as i cannot make a restore point or backup. Sure i can back up the system with acronis true image or some other such program but vista is not working properly. Any suggestions |
Volume shadow copy service failure | General Discussion | |||
| Volume Shadow Copy Service causing problems | Vista General | |||
| Volume Shadow Copy Service causing problems | Vista file management | |||
| Volume Shadow Copy Service error | Vista performance & maintenance | |||
| VSS (Volume Shadow Copy Service) | Vista General | |||
