Vista Forums
Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums
Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Chkdsk problem in Vista ultimate
Thread Tools Display Modes
Old 05-16-2008   #1
Newbie
mitsos1os is on a distinguished road
Windows Vista Ultimate 32 bit
Hi guys, I have the following problem. Everytime i run chkdsk through the command prompt it summarizes "Winows has checked and found problems on your file system" .I tried the command chkdsk/f several times, and it was performed after a restart, but when i log on to windows and try chkdsk again it says the same thing. Now the weird thing is that if I run chkdsk through Windows menu (C:drive-properties-tools-scandisk) but i only leave selected the second option (because if i have the first checked it will prompt me for a scan upon the restart), when it finishes it says windows didn't find any problems, but when i press details and see the log (which actually is what chkdsk appears on the command prompt) it says again that it found problems. This doesn't create a problem at the computers function, just gets on my nerves. Does anyone know what should i do? Oh I forgot to tell you that i even booted up from the norton ghost cd and used the implemented disk drive check. The first time it ran found some problems, but afterwards none.
mitsos1os is offline   Reply With Quote
Old 05-29-2008   #2
Newbie
Re: Chkdsk problem in Vista ultimate
anyone?
Old 05-29-2008   #3
Nonny
Guest
Posts: n/a
On Thu, 29 May 2008 12:02:27 -0500, mitsos1os
<guest@xxxxxx-email.com> wrote:
Quote:
>anyone?
It's been two weeks since you first posted your question.
It would be best if you quoted your original post rather than just
post as you did.
Display Modes
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
