Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
RB
Vista - svchost.exe and Sound + CPU usage...
05-17-2008   #1
Torsten Scharf
Hello,
in Front sorry for my English - so be patient with me.
My Desktop had a funny spleen - it makes some Noise like
'ding dong dong ding' couple of times
At same Time the Task manager will have between 60 and 95%
Inside the Taskmanager the svchost.exe takes a lot of the Performance
It will also involve the PnP Service, and Dcom Server or so
This will take between 10 til 15 minutes after each reboot
Has anyone any Idea to solve this conduct
Thanks
Torsten Scharf
MS Vista Ultimate SP1 Athlon64 X2 3800+ 3GB 2TB HD's (ext. + int.)
Nvidia 6600 Sound on Board Gigabyte GA-K8NXP-SLI
05-17-2008   #2
propman
Re: svchost.exe and Sound + CPU usage...
Torsten Scharf wrote:
Quote:
> Hello,
> Thanks
> Torsten Scharf
My gut reaction "low disk space" and "virtual memory swapping" (ie swap
file) but then I noticed your signature stating 2TB HD's! Still I think
I'd be taking a look at unhooking the external HD to see if the problem
still happens.....also look to see if you have automatic indexing of
your HD's toggled on.
RB
Similar Threads for: svchost.exe and Sound + CPU usage...
High CPU usage - svchost.exe, DcomLaunch and Plug & Play Vista General
DCOMLAUNCH SVCHOST Plug & Play, Hi CPU Usage Vista General
svchost.exe memory usage Vista performance & maintenance
vista dual monitor sound and usage Vista General
100% Processor usage - svchost.exe Vista performance & maintenance
