Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Functioning problems
Old 05-18-2008   #1 (permalink)
A
I was wondering if anyone else was having this problem:
I got my HDD and motherboard replaced recently. However, the same problem is
occuring as when I did before I got the parts replaced. I am a multi-tasker.
So I have about 7 tabs open in one browser, listening to music and going
through folders and such. After about an hour of using the computer I cannot
open any more tabs: I click on the New Tab but nothing happens. I also cannot
open any folders or files. No, my computer isn't frozen.
So basically, I can't open anything beyond that point. After I continue to
operate on my 7 tabs, one by one, they stop functioning, which results in me
closing the tabs until I have only 3 open. Now I am able to access the
internet, and even open folders. After another 20 minutes the 3 tabs don't
work. So I have to close another, and another until I have to restart the
computer again.
Anyone else having this problem?
Old 05-18-2008   #2 (permalink)
DL
Re: Functioning problems
Sound like you may have something consuming memory
"A" <A@xxxxxx> wrote in message
news:587FDE6A-288C-4EC2-A964-FA126BE62262@xxxxxx
> is
> multi-tasker.
> cannot
> cannot
> me
> computer again.
Old 05-18-2008   #3 (permalink)
Charlie Tame
> computer again.
Sounds like you probably use the same (Let's say) 7 things most of the
time. Try it without each in turn, for example run 1,2,3,4,5 and 6 and
if the problem goes way then program 7 is leaking memory. If not try
1,2,3,4,5, and 7.
If none of this works then maybe it is IE leaking memory, install and
try Firefox, see what happens then?
I mean you could list all that you that you usually run and hope someone
knows of a problem with one of them, up to you, but I think a process of
elimination is the reliable solution.
Video not functioning Vista General
'Categories' not functioning Live Messenger
WLM 2009 not functioning Live Messenger
Ultimate 64 not functioning with 8G ram Vista hardware & devices
mic is not functioning Vista hardware & devices
