| | Desktop background problems? Why, all of the sudden, anything I choose for a desktop background image is enlarged and out of focus? Not just an image I've downloaded, but the "stock" images also. I've tried the pixel gig and no luck. |
| Home premium 32 bit, SP1 | Re: Desktop background problems? Before looking for some fancy hot fix, let's not forget the old reliable -- system restore. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Desktop background problems? In addition to t-4-2's post: Have you changed your DPI (increased from 96 DPI) or screen resolution (decreased) settings? DPI: DPI Scaling Screen Resolution: Screen Resolution You might also check to see if trying different picture positions in step 5 of this tutorial to see if that helps any. Desktop Background Wallpaper Hope this helps, Shawn |
| Big vista problems need help icon/background/graphics/personalise problems | Vista performance & maintenance | |||
| Desktop background | Vista General | |||
| Desktop Background Incorrect Fit to Desktop | Vista performance & maintenance | |||
| can't set up desktop background | Vista performance & maintenance | |||
