Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - problems with disk clean up
Old 06-04-2008   #1 (permalink)
melinda
Used to, when I did disk clean up, it would let me delete "system memory
dump" but now it only calculates it, but does not even offer for me to delete
it. Why and how can I start to delete that again?
Old 06-10-2008   #2 (permalink)
Ramesh Srinivasan
Re: problems with disk clean up
The entry shows up only if there is atleast one .dmp file present in the
Windows directory or sub-directories. You can check it yourself:
Click Start, type:
cmd /k dir %windir%\*.dmp /s/a
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
The Winhelponline Blog: http://www.winhelponline.com/blog
Windows® Troubleshooting: http://www.winhelponline.com
"melinda" <melinda@xxxxxx> wrote in message
news:9499D52F-DBF7-44C7-BAC2-2A8D37BC591A@xxxxxx
delete
Solved SP1 Disk Clean up tool General Discussion
Make sure I don't have the disk clean up bug? General Discussion
window vista disk clean up Vista General
Clean Install from Upgrade disk Vista General
vista clean up disk General Discussion
