Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Spyware program not going away
Old 06-18-2008   #1 (permalink)
violet_eyesz
Hello, I was on my computer one time and this WInSpywareProtect program just
came on and it would not go away. I tried searching for it to delete it but I
could not find it. It just pops up at the worst time and won't go away. I
need help in deleting it.
Old 06-18-2008   #2 (permalink)
Carey Frisch [MVP]
Re: Spyware program not going away
Download and run Ad-Aware:
http://www.lavasoftusa.com/products/ad_aware_free.php
Carey Frisch
Microsoft MVP
Windows Desktop Experience -
Windows Vista Enthusiast
"violet_eyesz" <violet_eyesz@xxxxxx> wrote in message news:9BEC9601-C81D-4CA7-902F-0645ABBD1F4A@xxxxxx
Old 06-18-2008   #3 (permalink)
Malke
This won't do it. The OP will need a more focused cleaning.
Malke
MS-MVP
Elephant Boy Computers
www.elephantboycomputers.com
Don't Panic!
Old 06-18-2008   #4 (permalink)
Malke
violet_eyesz wrote:
> just came on and it would not go away. I tried searching for it to delete
> it but I could not find it. It just pops up at the worst time and won't go
> away. I need help in deleting it.
Start with specific removal instructions by finding your malware here:
Bleeping Computer removal how-to's -
http://www.bleepingcomputer.com/forums/forum55.html
If you need more help, register at BleepingComputer's forum, read the
posting FAQ, and get guided help. There are other specialty forums that do
this, too.
http://aumha.net/ - Click on the HijackThis forum. Read the announcement and
the stickies *first*.
http://www.atribune.org/forums/index.php?showforum=9
http://aumha.net/viewforum.php?f=30
http://www.bleepingcomputer.com/forums/forum22.html
http://castlecops.com/forum67.html
http://www.dslreports.com/forum/cleanup
http://www.cybertechhelp.com/forums/...splay.php?f=25
http://www.geekstogo.com/forum/Malwa..._Here-f37.html
http://gladiator-antivirus.com/forum...?showforum=170
http://spywarewarrior.com/viewforum.php?f=5
http://forums.techguy.org/54-security/
http://forums.tomcoyote.org/
Malke
MS-MVP
Don't Panic!
Old 06-18-2008   #5 (permalink)
The Coward Robert Ford
=?Utf-8?B?dmlvbGV0X2V5ZXN6?= <violet_eyesz@xxxxxx>
wrote in news:9BEC9601-C81D-4CA7-902F-0645ABBD1F4A@xxxxxx:
> program just came on and it would not go away. I tried searching for
> it to delete it but I could not find it. It just pops up at the worst
> time and won't go away. I need help in deleting it.
http://removal-tool.com/winspywareprotect/
Old 06-18-2008   #6 (permalink)
Mick Murphy
RE: Spyware program not going away
Install Spybot Search & destroy, and run it in Safe Mode to remove problem.
Instructions for download/install, and running in Safe Mode written below.
http://www.spybot.info/en/index.html
Spybot Search & Destroy 1.5.2 is a very good, FREE Anti-Spyware Program.
Download, install, update, and immunize your System with it.
Then SCAN with it.
Update it, and scan your System once a fortnight.
http://www.javacoolsoftware.com/spywareblaster.html
Important re: Safe Mode
If you happen to find a problem that you can’t uninstall / delete, reboot
the computer, and go into Safe Mode.
To get into Safe mode, tap F8 right at Power On / Startup, and use UP arrow
key to get to Safe Mode, then hit ENTER.
RESCAN your computer with Spybot S & D while in Safe Mode.
Mick Murphy - Qld - Australia
Old 06-19-2008   #7 (permalink)
ICQM Houston
use ZoneAlarm http://www.zonealarm.com - do nt use free download (or try it
ffree) - buy it! good luck
spyware removal program? Software
Removing a Spyware program Vista performance & maintenance
can i use more then one anti-spyware program? what are good on vista? Vista security
Spyware Program Vista General
Spyware .exe program won't save or run into Program Files folder Vista General
