Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
DVD burner problems with vista home premium
Update your Vista Drivers Update Your Drivers Now!!
Closed Thread
Thread Tools Display Modes
Old 07-01-2008   #1 (permalink)
Rosemary
Guest
I am unable to use my DVD/CD writer. When I insert a disc, a blue screen
appears and the computer reboots. The blue screen mentions something about
a fatal error.
What should I do?
roses
Old 07-02-2008   #2 (permalink)
Spirit
Guest
Re: DVD burner problems with vista home premium
Try RESTORE if you can go back before the error started happening.
IF that does not work or is not possible then boot into Safe Mode
then Device Manager and DELETE the drive. Reboot and let it
reload the drivers.
By chance did you load any program that might have been the cause
of the problem?
"Rosemary" <Rose1095@xxxxxx> wrote in message news:7DD3CC98-F427-486D-83CC-0D3477786044@xxxxxx
> a fatal error.
> What should I do?
> roses
Old 07-02-2008   #3 (permalink)
Rosemary
Guest
Thanks
I solved it by deleting some registry keys. I went to the Vista help and
support website and followed directions. I searched using Blue Screen.
"Spirit" <noone@xxxxxx> wrote in message
news:OxRlsRB3IHA.2336@xxxxxx
reload the drivers.
of the problem?
> about
> a fatal error.
> What should I do?
> roses
Closed Thread
Display Modes
Vista Home Premium Problems E-Layer Vista installation & setup 1 04-12-2008 10:20 PM
iTunes install removing CD/DVD burner from Vista Home Premium DavidH Vista General 0 04-12-2008 01:21 PM
Vista home premium problems Paul Vista General 4 03-30-2008 02:19 AM
My first problems using vista home premium Temet Nosce Vista General 3 08-28-2007 09:17 AM
dvd problems in vista home premium clockman Vista General 0 06-02-2007 08:38 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
