br> br> |
| | Thread Tools | Display Modes |
| Guest | Very Serious Resolution Issue Here is what happened: My screen can only support 1600x900 resolution,l but i didnt know that and when experimenting, i changed it to 1600x1000, which turned the screen black and displayed the message "out of range" or something like that. I sat still for some minutes, expecting the system to restore the previous resolution setting, as you know it does unless "YES, keep this resolution" is pressed, but nothing happened. So now im online with my Scientific Linux Live edition, asking for your assistance. How can i restore my user resolution? |
| | #2 (permalink) | ||||||||||||
| Guest | RE: Very Serious Resolution Issue Right, forgot... Im using WIndows Vista Home Premium. "Rahvasaadik" wrote:
| | #3 (permalink) | ||||||||||||
| Guest | Re: Very Serious Resolution Issue Rahvasaadik wrote:
Regular Mode and set it to the correct resolution. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ | ||||||||||||
| | #4 (permalink) | ||||||||||||
| Guest | RE: Very Serious Resolution Issue Boot into safe mode and then change the resolution. -- Paul "Rahvasaadik" wrote:
| | #5 (permalink) | ||||||||||||
| Guest | RE: Very Serious Resolution Issue The other and maybe better option is to boot to the screen that allows safe mode and select "Enable low-resolution video (640x480)" instead of safe mode and the change the resolution back to what you want. -- Paul "Rahvasaadik" wrote:
| | #6 (permalink) | ||||||||||||||||||||||||
| Guest | RE: Very Serious Resolution Issue Ill try that, although im not so sure, cause i tried to change resolution in safe mode, but rebooting back to my user, the resolution was still the same. Does vista store safe mode and user resolutions separately? "PaulB" wrote:
| | #7 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | RE: Very Serious Resolution Issue It did not work! (changing the resolution in safe mode) the screen keeps returning it to the set default 1600x1000. "Rahvasaadik" wrote:
| | #8 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | RE: Very Serious Resolution Issue Don't go in to safe mode . Select the other option of "Enable low-resolution video (640x480)" instead. -- Paul "Rahvasaadik" wrote:
| | #9 (permalink) | ||||||||||||||||||||||||||||||||||||
| Guest | RE: Very Serious Resolution Issue Hi, Have you tried the other option, 'Last Known Good Configuration (advanced)? Dwarf "PaulB" wrote:
| Display Modes | |
| Windows Vista mouse issue.. Possibly ease of use type issue? | Malakie | Vista hardware & devices | 0 | 07-10-2008 04:30 PM |
| Vista SP1 issue and resolution | robert.winstanley | Vista General | 0 | 03-20-2008 07:28 AM |
| Video driver issue - can't change resolution | Wowbagger | Vista hardware & devices | 2 | 02-21-2008 08:04 AM |
| Monitor Drivers? X64 Display Resolution Issue | the.cosmic.pope | Drivers | 9 | 02-06-2008 10:02 AM |
| Live Cam VX-6000 Resolution issue | Jeffray L | Vista hardware & devices | 0 | 08-06-2007 01:42 PM |
