| Vista Ultimate X64 SP2 | How to speed up Vista Many people I see are having a problem in regards to either a slow boot up, or that windows is slow to load Programs. I am using a SATA RAID 0 config, and even with 4GB of ram This can result in heavy fragmentation and a slow system- especially after recording tv on MCE or any other activity that writes large files to disk. Deframenting speeds up the system dramatically, BUT using the default defragmentation doesn't defrag files bigger than 64MB. So here are two steps to a faster system: 1. Do a full defrag- all files Start>All Programs>Acessories>Right Click Command Prompt>"Run as Administrator">at command prompt, copy and paste the following: defrag c: -w 2. Check disk for errors Start>Computer>Right Click "C" drive>Click Properties>Tools>Error Checking-Click "Check Now">Under Check Disk Options click "Automatically fix file system errors" and "Scan for and attempt recovery of bad sectors"> Restart Computer (note-substitute "c" for the drive letter you want to defrag/check for errors) When computer restarts after check disk you will notice system is much faster, and more responsive. Last edited by rive0108; 07-03-2008 at 08:43 PM.. |
| | Re: How to speed up Vista |
| Can you speed up download speed from ISP | General Discussion | |||
| Vista Home Premium. Admin Account WiFi Speed Good. Other User Account Speed Not So Good. | Vista General | |||
| Help! Vista Home Premium. Admin Account WiFi Speed Good. Other User Account Speed Not So Good. | Vista networking & sharing | |||
| Network speed is half or one third of speed on XP | Vista General | |||
| How to check your Speed Boost tested memory speed | Vista General | |||
