Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista Tutorial - shadow copy time out when trying to create system restore point
Old 07-06-2008   #1 (permalink)
liketreo
Guest
I have a vista ultimate 64 bit OS. I am not able to manually create a system
restore point (nor is the system able to do so automatically--so none
currently exist).
I get the error message (after a long time): "The restore point could not be
created for the following reason: The creation of a shadow copy has timed
out. Try again this operation (0x81000101).
I also have windows live one care running but a) I have tried this with it
disabled after following instructions in
http://support.microsoft.com/kb/910654 and b) previous to a couple of days
ago, there were no problems it run the system was able to create the restore
points automatically.
I have tried to turn off/on system restore point (thus losing the previous
ones) and then to "create"with the same issue.
I have tried to enable services.msc in automatic mode including: Microsoft
software shadow copy provider, virtual disk, and volume shadow copy, and have
restarted the computer after making the changes, with no difference.
How do I get this thing (HP Pavillion m9200z CTO desktop) to create a system
restore point?
Thanks,
Jordan
System Restore error (create restore point), event ID: 8193 Vista General
is there a way to disable shadow copy but retain restore point function Vista General
System Restore Points without shadow copy - there has got to be a way!! Vista file management
System Restore Points without shadow copy - there has got to be a way!! Vista General
Finding shadow copy and restore point snapshots Vista file management
