| | Problem Reports and Solutions.....? Ok, I've had some troubles with my system, there has been reports sent out automatically (this is the way I have it set up). My question is, why does this Procedure (problems and reports I mean) say that there are solutions to 2 of my problems when there are none? If I right click on either one of those 2 reports that are supposed to have solutions, and I select "View Solution", it takes me to a site that says there "Are no solutions to this problem". Any constuctive ideas? Thank you for your time. |
| | Re: Problem Reports and Solutions.....? Anybody???? Nobody else is experiencing this, nor has an answer/comment/whatever as to why it would happen? "Dirty Dawg" <dirtydawg@xxxxxx> wrote in message news:eP4%23KwP6IHA.4596@xxxxxx Quote: > Ok, I've had some troubles with my system, there has been reports sent out > automatically (this is the way I have it set up). My question is, why > does this Procedure (problems and reports I mean) say that there are > solutions to 2 of my problems when there are none? If I right click on > either one of those 2 reports that are supposed to have solutions, and I > select "View Solution", it takes me to a site that says there "Are no > solutions to this problem". Any constuctive ideas? Thank you for your > time. > > |
| Problem Reports and Solutions | Vista General | |||
| Problem Reports and Solutions KB | Vista General | |||
| problem reports and solutions | Vista General | |||
| Problem Reports & Solutions | Vista performance & maintenance | |||
