Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista Backup
Closed Thread
Thread Tools Display Modes
Old 07-23-2008   #1 (permalink)
Newbie
  steverashi is offline
Vista Backup
We are currnetly using Vista on a few of our machines and run a scheduled backup every night. Is there a way to do a full backup each night and replace the existing one rather than doing an incremental backup. The machines that are running XP do this no problem but the Vista machines create a new folder each time which is using a large amount of space on the drive.
Old 07-23-2008   #2 (permalink)
Mark H
Guest
Re: Vista Backup
http://www.maximumpcguides.com/sched...ete-pc-backup/
Also, look at the second screenshot in this next article: (This is not the
task scheduler.)
http://www.microsoft.com/windows/win...es/backup.aspx
If that little checkbox is not selected (I'm sure there is an associated
registry entry somewhere.) then all your backups will be incremental after
the first full backup. (Unless the backup is over 30 days old.) The only way
to access this checkbox is to schedule your backups through the backup
scheduling wizard.
The wbadmin command looks at the parameter (checkbox) above to determine if
a full or incremental backup is to be performed. Unfortunately, it is not
part of the wbadmin command that you can maniuplate.
Another option is to use the elevated command before performing the backup:
wbadmin delete catalog
If Vista backup does not see a catalog, it will assume a full backup is
required. (Just not sure how this will work with multiple machines backing
up to the same drive.)
"steverashi" <guest@xxxxxx-email.com> wrote in message
news:6ba0671380760160e5f87a2f5f1deb59@xxxxxx-gateway.com...
> steverashi
Old 07-23-2008   #3 (permalink)
TheShadow's Avatar
Retired PC Builder
  TheShadow is offline
Re: Vista Backup
Developing a foolproof backup system for any PC is a very exacting process.
(I've been setting up backup systems for home and business for almost 30 years)
There is NO WAY you can have a good backup if it's on the same drive as the OS.
At least two drives are required. Or, your main drive and some other suitable media.
A backup to a second partition on the main drive is NO backup at all when the drive squalls, balls and smokes! YES, that really does happen!
A Second Drive is required for a really safe backup. That can be another internal hard drive, or an external drive. It can even be a burned Image of your OS drive, on a DVD.
But whatever the backup media, it should be able to do a full restore to a new HD, in case that the original drive is no longer operable.
I've been using Ghost since it was first released in 1997, long before it was purchased by Symantec. (Norton)
I can do quickie backups of my C: partition to my D: partition in just over five minutes. That's a compressed Image File of C:. I can store many such images on my D: drive that's four times the size of my C: drive. (Same drive, two partitions.)
If something happens on my C: drive that a System Restore can't fix, I do a quick "Image to Partition" Restore and in about six minutes my C: drive is restored and I'm back in operation.
So what do I do if my main HD totally shoots craps?
WELL, once a week I do a Disk Image of C: to a DVD. Ghost puts itself on the DVD, in the boot sector, thus making my restore DVD boot to Ghost.
Toshiba's System Restore DVD is made this way, using Norton's Ghost.
I can boot up my system with that DVD and do my Restore, to a brand new HD if necessary.
For many years I've repeated the saying, "The only bad backup is the one you decided NOT to make".
If you want a FREE program to do full disk backups, the "MaxBlast" or "SeaTools" programs are the ticket. They are almost identical and written by "Acronis True Image" and both are available for download from the Maxtor or Seagate web sites. I've tested both to make bootable backups of Vista Ultimate, and they work just fine.
Good Luck,
The Shadow
Old 07-23-2008   #4 (permalink)
Mark H
Guest
Re: Vista Backup
Did you just have an urge to speak, or did this have something to do with
the OP?
"TheShadow" <guest@xxxxxx-email.com> wrote in message
news:67bb2204a91bec9bc7e1663382978c49@xxxxxx-gateway.com...
> process.
> 30 years)
> the OS.
> suitable media.
> happen!
> Ghost.
> HD if necessary.
> Good Luck,
> The Shadow
> TheShadow
> A person with experience, is never at the mercy of a person with an
> argument.
Old 07-23-2008   #5 (permalink)
James McTavish
Guest
Re: Vista Backup
"Mark H" <jmhonzell@xxxxxx> wrote in news:#m3BFxN7IHA.4864
@TK2MSFTNGP06.phx.gbl:
> the OP?
Yea, he was explaining how to do backups better with the right tools for
the job. I use Acronis True Image instead of Ghost to do the same thing. I
keep a backup on a second HDD and an external USB HDD.
http://www.acronis.com/homecomputing...cts/trueimage/
Old 07-24-2008   #6 (permalink)
Newbie
Re: Vista Backup
In response to "The Shadow". All backups are onto a seperate machine which is then backed up to an external HD. The problem is that the Vista backups are taking up a lot of space. The XP machines that backup replace the existing one. The Vista machines, which we have 4, do an incremental backup. We don't backup the entire machine just a selection of folders.
Closed Thread
Display Modes
why Vista Backup utility dont make backup of aspx files? Berny Vista General 1 12-23-2007 03:37 PM
best backup software for Vista Home Ultimate that will allow me toselect files and folders to backup and restore Lisa Hetherington Vista performance & maintenance 6 10-20-2007 08:29 PM
Vista File Backup - Backup Files From A Share Regardless Of Locati Dell Boy Vista General 8 09-13-2007 12:01 AM
Backup/Restore using Vista Backup not recognising 2nd SATA drive ChrisBeeChris Vista performance & maintenance 3 06-01-2007 03:47 AM
Using Vista Backup To Backup To XP-based Network Share jim.haselmaier@comcast.net Vista General 1 05-02-2007 04:45 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
