| | Best Vista file system repair/maintenance utility? I am having difficulty finding a "safe" file system maintenance utility, namely one which will _not_ damage the Vista file system further. (do no harm) My Vista Ultimate was running fine, as near as I could determine, all my apps ran okay. So I decided to do routine maintenance of my NTFS. (file system) There were literally dozens of utilities to choose from, so being thoroughly confused, I blindly chose "RegCure" from a Canadian firm for $30. Big Mistake. Vista promptly crashed after the file system repair. Is there any such thing as a safe file system repair utility? Mark- |
| | Re: Best Vista file system repair/maintenance utility? "Mark Conrad" <this.is@xxxxxx> wrote: Quote: > I am having difficulty finding a "safe" file system > maintenance utility, namely one which will _not_ > damage the Vista file system further. (do no harm) > > My Vista Ultimate was running fine, as near as I > could determine, all my apps ran okay. > > So I decided to do routine maintenance of my NTFS. > (file system) > > There were literally dozens of utilities to choose > from, so being thoroughly confused, I blindly > chose "RegCure" from a Canadian firm for $30. system maintenance. You have obviously already learned of the damage potential such programs have. Also, there is little to none performance to (re-)gain by using them. <snip> Quote: > Is there any such thing as a safe file system repair > utility? http://msdn.microsoft.com/en-us/libr...41(VS.85).aspx Take a look at these two Windows apps as well, they come in handy when you need to maintain your system. Disk defragmenter: http://windowshelp.microsoft.com/Win...598e31033.mspx Chkdsk: http://windowshelp.microsoft.com/Win...41f811033.mspx Charlie42 |
| | Re: Best Vista file system repair/maintenance utility? In article <euDSg8#8IHA.5928@xxxxxx>, Charlie42 <Charlie42@xxxxxx> wrote: Quote: Quote: > > Is there any such thing as a safe file system repair > > utility? > Sure. Windows's built-in System File Checker tool: > > http://msdn.microsoft.com/en-us/libr...41(VS.85).aspx > > Take a look at these two Windows apps as well, they come in handy when you > need to maintain your system. > > Disk defragmenter: > > http://windowshelp.microsoft.com/Win...4-4716-97a7-61 > 2a1f0598e31033.mspx > > Chkdsk: > > http://windowshelp.microsoft.com/Win...c-79c7-0f91-93 > 37c2c41f811033.mspx > > Charlie42 Thanks for all those references, will try them. Just beginning with Vista, do not know my way around yet. Will take your advice about anything mentioning registry cleaning, and avoid such utilities in the future. Mark- |
| | Re: Best Vista file system repair/maintenance utility? On Fri, 01 Aug 2008 08:35:18 -0700, Mark Conrad <this.is@xxxxxx> wrote: Quote: > > I am having difficulty finding a "safe" file system > maintenance utility, namely one which will _not_ > damage the Vista file system further. (do no harm) Exactly what do you mean by "file system maintenance utility"? Quote: > My Vista Ultimate was running fine, as near as I > could determine, all my apps ran okay. > > So I decided to do routine maintenance of my NTFS. > (file system) No such maintenance, routine or otherwise, is required. There are many software products on the market that are advertised as magical panaceas to tune up your system, improve performance, etc. Almost without exception, these are all snake oil. They do nothing that needs to be done, and in many cases *cause* problems rather than alleviating them. I recommend that you avoid them like the plague. Quote: > There were literally dozens of utilities to choose > from, so being thoroughly confused, Yes, and as I said, they should *all* be avoided. You had no problems, and yet you wanted to get a product that purported to (but really didn't) solve any problems. That makes no sense to me. Quote: > I blindly > chose Then, to make matters worse, you chose blindly? Quote: > "RegCure" from a Canadian firm for $30. Moreover, you didn't even choose what you were looking for in the first place--a "file system maintenance utility," but instead chose a registry cleaner. Registry cleaners are a classic example of what I mentioned above--snake oil. Cleaning of the registry isn't needed and is dangerous. Leave the registry alone and don't use any registry cleaner. Despite what many people think, and what vendors of registry cleaning software try to convince you of, having unused registry entries doesn't really hurt you. Quote: > Big Mistake. Undoubtedly. Quote: > Vista promptly crashed after the file system repair. Again, registry cleaners don't do anything like "file system repair." Quote: > Is there any such thing as a safe file system repair > utility? My advice to you is to heed the classic warning "don't fix what ain't broke." If you should have a specific problem, ask us here how to troubleshoot and fix it. The solution will hardly ever be to use such a program. Do *not* look for magical panaceas, and always remember that almost all such software products are junk, and are much more likely to hurt you than help. I'm sorry you wasted your $30, and I'm sorry that Vista crashed, but I hope that at least you've learned a valuable lesson. -- Ken Blake, Microsoft MVP - Windows Desktop Experience Please Reply to the Newsgroup |
| | Re: Best Vista file system repair/maintenance utility? You guys come across somewhat harshly. The O.P. made an honest mistake. A google search does reveal that regcure causes major problems but why jump on him? As for Vista being trouble free....don't bet on it! I am into trialling vista ultimate for the 4th time after a BSOD wiped out my last ultimate installed OS beyond recovery. Cheers Ron |
| | #6 (permalink) |
| Vista Ultimate x64 | Re: Best Vista file system repair/maintenance utility? One program I can HIGHLY recommend is R-Studio File Recovery and Data Recovery Software. Hard Drive recovery utility . It is pricey but I found that out of all the recovery tools I looked into buying/testing/demoing this was by far the quickest as well as the most responsive. I've also made a habit of making disk images of my base vista x64 install and then keeping incremental backups. The program I'm using is Macrium Reflect Macrium Reflect Backup and Disk Image software for Windows XP, Vista and Server 2003 . |
| Computer Repair Utility Kit | Software | |||
| System maintenance not in control panel |Vista x64 home premium | Vista hardware & devices | |||
| Looking for Utility to Repair vista bootloader? | Vista General | |||
| HELP!!! Any utility to repair Windiow Mail message store? | Vista mail | |||
| NTLDR is missing, unable to run repair utility | Vista General | |||
