1.    14 Aug 2008 #1
    ing. Muskus Guest
    HELP KB936330
    Hi peeps,
    I'm a new Vista user..
    A few weeks ago I saw that KB936330 (published 13-5-2008) was ready to be
    installed and it was listed as an important update. After installing it I had
    to restart my pc, that went well.
    Then I got a screen: Configuring updates, stage 3 of 3 100% complete. Do not
    turn off your computer.. That lasted like 13 minutes, the pc shut down by
    itself, restarted and I got the same screen again. This went on a few times.
    I decided to use the on/off button and shut down the pc manually. After I
    restarted it, I got the same screen! It actually took me a few hours to
    finally log on into my pc, and I restored it to before that update. 8-8-08 I
    did a dumb thing by installing the same update again! Same story, I had to
    restore my pc again after a few hours. Now I'm checking for updates again, I
    see the same update, You can surely understand I'm not going to install it,
    but can anybody please tell me, what is wrong with it and how can I delete it
    so I won't get any more notifications about it?
    Thanks for the help.
    Everyman Got the Right to decide his own Destiny
  2.    14 Aug 2008 #2
    home premium vista (64bit)
    Local Time: 05:42
    Re: HELP KB936330
    KB936330
    Windows Vista Service Pack 1 (SP1) is an update to Windows Vista that addresses feedback from our customers. In addition to previously released updates, SP1 will contain changes focused on addressing specific reliability, performance, and compatibility issues; supporting new types of hardware; and adding support for several emerging standards. SP1 also will continue to make it easier for IT administrators to deploy and manage Windows Vista. Windows Vista Service Pack 1 Five Language Standalone version can be installed on systems with any of the following language versions: English (US), French, German, Japanese, or Spanish (Traditional).
    scrooge
  3.    14 Aug 2008 #3
    ing. Muskus Guest
    Re: HELP KB936330
    Ok, so it's an farely important one. The only problem is I cant install it,
    Cause I won't be able to use my laptop. It keeps restarting and I don't get
    any error codes.
    What can I do?
    "scrooge" wrote:
    > KB936330
    > *Windows Vista Service Pack 1 (SP1)* is an update to Windows Vista that
    > scrooge
    > scrooge
  4.    14 Aug 2008 #4
    Local Time: 05:42
    Re: HELP KB936330
    just start the install before you go to bed . when you get up it should be done . as for the rebooting it's all part of the install and if i remember it took about 1 hour to
    get done.
    scrooge
  5.    14 Aug 2008 #5
    Mick Murphy Guest
    Re: HELP KB936330
    https://support.microsoft.com/oas/de...4&gprid=500921
    Above link is FREE help from MS for Service Pack 1 problems
    Give then a try.
    Mick Murphy - Qld - Australia
    > any error codes.
    > What can I do?
    > "scrooge" wrote:
    > > KB936330
    > > scrooge
    > > scrooge
  6.    15 Aug 2008 #6
    ing. Muskus Guest
    Re: HELP KB936330
    ok, rebooting is part of the install, it took you one hour, mine takes about
    4 to 5 hours, is that Normal??
    Thanks for the help. I'll check the support and I'll install it before I go
    to bed.
    > get done.
    > scrooge
    > scrooge
keep downloading sp 1 (kb936330) over and over
Did window on my laptop, BUT: keep downloading kb936330 over and over, I am stuck and I cannot get passed that. It will say that it was...
Windows Updates
service pack 1 KB936330
Hello, I am running Windows Vista 32bit. I have tried over and over and downloading this update and after installation I always get a message...
Windows Updates
Sp 1 ( kb936330
HelloI am unable to install this update I am getting an error message that say - ( windows vista service pack 1 cannot be installed on your...
Windows Updates
( kb936330 )
Hello do anyone have any information on this update ? I am running Windows Vista ultimate 32bit . I downloaded this update and unfortunately...
Windows Updates
vISTA SERVICE PACK (KB936330)
Is anybody else having difficulty with this download
Vista General
KB936330 vista sp1
two (2) tries to install both times "failed" that's all that is displayed new dell machine worked fine (till now) any ideas?? (please)
Vista installation & setup
KB936330 Vista SP1 Beta
Today I received KB936330 Vista SP1 Beta through the Vista automatic update feature. In reading the instructions to KB936330 it says I need to...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
