While it might be a moral booster to re-install the operating system simply
because of a virus/malware it certainly isn't a necessity. if your Anti
Virus/Malware/spyware software is doing its job then the
virus/malware/spyware should be automatically ether quarantine or removed
from your 'main' system. What people forget is that Windows creates what I
call a 'subsystem' in the form of Restore points and you can bet that the
virus/malware/spyware has hid itself comfortably there just waiting for you
to restore your system back. In this situation I find it more useful to let
the anti virus/malware/spyware application do its job and clear the virus
etc. As soon as this is done I immediately delete the system restore points.
I can then create a new restore point from scratch thus preventing a further
infection.
John Barnett MVP
Associate Expert
Windows Desktop Experience
Web:
http://xphelpandsupport.mvps.org
Web:
http://vistasupport.mvps.org
The information in this mail/post is supplied "as is". No warranty of any
kind, either expressed or implied, is made in relation to the accuracy,
reliability or content of this mail/post. The Author shall not be liable for
any direct, indirect, incidental or consequential damages arising out of the
use of, or inability to use, information or opinions expressed in this
mail/post..
"Victek" <Victek@xxxxxx> wrote in message
news:0D12D42D-EE29-4496-B39A-A324F72A22ED@xxxxxx
> "Bruce Chambers" <bchambers@xxxxxx> wrote in message
> news:#s6tavHAJHA.3804@xxxxxx
>> Nurock wrote:
>>> I picked a malware problem, (Antivirus XP2008). I have a back-up of all
>>> of my data on an external hard drive that I made just before I got the
>>> virus. if I reformat my whole computer and reload Vista Home Premium,
>>> then reload my data from the external hard drive, should that fix all of
>>> my problems? >>
>> Formatting the hard drive to solve a virus or spyware problem is
>> rather like using an axe to trim one's fingernails. Sure, it'll get the
>> job done, but it's rather time-consuming, and almost always unnecessary.
>> > Well, there are different schools of thought about this. Some think that
> once you get infected the only way to be certain the system is clean is to
> format and reinstall. If the system is functional enough I agree it's
> worth making an effort to clean it first. By using a combination of
> anti-malware tools I can feel pretty confident the system is clean, but
> there may be lingering damage. For instance a common problem I've seen is
> a task manager with the top menu cutoff. This is probably an example of
> registry corruption. It may be possible to fix this kind of thing by
> editing the registry directly, but how? If would be great if someone put
> up a FAQ.
