| | CPU Load problem Vista RC1 - When launching Task manager it constantly shows 40%-60% CPU load, even when no other application is running. System (NT kernel & System) process takes around 10%, svchost takes 20%-30% and System Idle process is around 50% (this one takes no less then 97% on my XP, same hardware). Is this normal? [P4HT/3GHz/1GB] TIA |
| problem with nvidia down load | Vista installation & setup | |||
| Dynamic load of assembly problem | PowerShell | |||
| CPU Load problem | Vista performance & maintenance | |||
| driver load problem | Vista General | |||
