I have an issue that is mind-blowing: I did an upgrade to Vista over XP Pro,
SP2. I have word 2002. I have a document that has tables in it. When I open
that document, my cpu utilization jumps to 100% and I get a rapid flashing of
wait/cursor while the document is open and it is word.exe that is causing the
spiking jumps. If I open a menu, which takes focus off the document, then,
after a delay, the cpu monitor drops down into the low teens and high single
digits again.
I did some experiments today and opened a bunch of different documents. Only
a small handful cause this strange behavior and to nowhere near the cpu jump
my one document with all the tables in it has. In one instance that I did not
repro, when I closed Word, I still had 99% cpu, and checking processes it was
explorer. I ended the process and cpu meter dropped right back down.
Further experiment: I can open Word with just a blip on the meter. I just
happened, with a blank document, to open the Page Setup and as soon as I did
so, I started getting the cpu cycles jumping up and hitting 100%.
I need to uninstall and reinstall my Office XP small business edition but
have been holding off hoping I would get some answer from someone before I do
so.
"Bert" wrote:
> I'm seeing the same problem. I hope somebody has an answer because
> explorer.exe just jumped up to 45-50% today, causing my system to run at 100%
> CPU load all the time.
> Intel D865GBF MB
> Intel P4HT 3.2 gHz
> Nvidia FX5200
> 160 Gb Eide Drive
> Bert
> "Albert Gross" wrote:
> > "JJ" wrote:
> > > Only see 2-4% cpu load (with some background services active) on mine.
> > > Physical memory is around 50% utilized though.
> > > John
> > > PC: (XPS Gen 1) laptop
> > > Mem 1 gb
> > > processor P4 3.4
> > > Video ATI 9800 256 MB
> > > Vista RC1 build 5600
> > > Base score 4.3
> > > "Yoavb" wrote:
> > > > Vista RC1 - When launching Task manager it constantly shows 40%-60% CPU load,
> > > > even when no other application is running. System (NT kernel & System)
> > > > process takes around 10%, svchost takes 20%-30% and System Idle process is
> > > > around 50% (this one takes no less then 97% on my XP, same hardware). Is this
> > > > normal?
> > > > [P4HT/3GHz/1GB]
> > > > TIA
> > I am also receiving 100 precent CPU usage. the ZCfgSvc.exe process is using
> > up any spare CPU time available.
> > XPS Gen 2
> > 2Ghz Pentium M
> > 1GB Ram
> > NVIDIA Geforce Go 6800 Ultra
