| | shell32.dll not found - Vista Home Premium won't start! I have a PC to sort out which has the following issue: On starting up, and before the Windows logo displays it throws up an error message: = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Title bar text: LogonUI.exe This application has failed to start because SHELL32.dll was not found. RE-installing the application may fix the problem. = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Clicking on [OK] then displays the Windows logo, followed by the coloured background with 'Windows Vista Home Premium' at the bottom, following which on a black screen I get two error messages. The first is the same as that above except that the file quoted in the title bar is Explorer.exe. The second error message appearing behind this one advises that the 'Task Schedulaer Engine' has stopped responding, clicking [Close program] on this (and further) error messages I get explorere.exe has stopped working, and Windows Problem Reporting and stopped working. Starting in Safe Mode I get to the black and empty desktop with the Safe Mode labels in the corners but nothing appears to be happening. Entering 'Task Manager' via Ctrl-Alt-Del again gives the same sort of error but this time the Title Bar of the error box (referring to SHELL32.dll) is headed Taskmgr.exe. I have tried the Vista Startup Repair but that had no effect. SHELL32.DLL is the same size and data and time in System32 as it is in Dllcache. Any ideas how to sort this out? Is it a re-install? The machine is an HP and has a recovery partition. An early replay appreciated. TIA |
| Entry Point Not Found SHELL32.dll error??? | Vista performance & maintenance | |||
| System restore not found in home premium help | Vista General | |||
| RE: Vista Home Premium won't start anymore | Vista installation & setup | |||
| Vista Home Premium - Windows Movie Maker not found | Vista music pictures video | |||
| PVR150 not found after upgrade to Vista home premium | Vista hardware & devices | |||
