| | FAN IS RUNNING NON STOP!! NEED HELP HEY.. I HAVE A PROBLEM WITH THE FAN, THE LAPTOP IS A TX2120, FAIRLY NEW WITH A FEW MONTHS OLD, ALWAYS KEPT IN MY BEDROOM, THE ISSUE IS THAT THE FAN IS ALWAYS RUNNING SUPER FAST, AND WITHOUHG HAVING ANY WINDOWS OR MESSENGER OPEN, HOW CAN I DEAL WITH THIS SITUATION, BECAUSE THE NOISE IS DRIVING ME CRAZY, AND IS MAKING THE KEYBOARD A BIT HOTTHEIS LAPTOP IS RUNNING VISTA HOME PREMIUM WITH 64BITTHANKSSSSS Post Originated from http://www.VistaForums.com Vista Support Forums |
| | Re: FAN IS RUNNING NON STOP!! NEED HELP "ed_judo" wrote in message news:%233bLd1GDJHA.1184@xxxxxx Quote: > HEY.. I HAVE A PROBLEM WITH THE FAN, THE LAPTOP IS A TX2120, FAIRLY NEW > WITH A FEW MONTHS OLD, ALWAYS KEPT IN MY BEDROOM, THE ISSUE IS THAT THE > FAN IS ALWAYS RUNNING SUPER FAST, AND WITHOUHG HAVING ANY WINDOWS OR > MESSENGER OPEN, HOW CAN I DEAL WITH THIS SITUATION, BECAUSE THE NOISE > IS DRIVING ME CRAZY, AND IS MAKING THE KEYBOARD A BIT HOTTHEIS LAPTOP IS > RUNNING VISTA HOME PREMIUM WITH 64BITTHANKSSSSS > > > Post Originated from http://www.VistaForums.com Vista Support Forums I have the TX2510us and the fan is set in the BIOS to run all the time. You may want to check to see what your bios setting for the fan is. Also check your Power Options settings in the control Panel. If you are set for High Performance the fan will tend to run longer. I have mine set at HP Recommended and I hardly notice the fan noise. |
| | Re: FAN IS RUNNING NON STOP!! NEED HELP Hey thanks for the reply, but the problem is that when I go to the BIOS, there is no fan selection, what should I do? and as you said, i am running on recommended power thanks |
| | Re: FAN IS RUNNING NON STOP!! NEED HELP Since you claim keyboard is warm while fan blows full speed check laptop ventilation - dusted air holes in the case, fan, CPU heat-sink. Open the laptop and give it a good blow or use an air can. Michael "FAN STILL GOING FAST" <FAN STILL GOING FAST@xxxxxx> wrote in message news:9D698C17-8642-4242-AADD-F31C6FD71674@xxxxxx Quote: > Hey thanks for the reply, but the problem is that when I go to the BIOS, > there is no fan selection, what should I do? and as you said, i am running > on > recommended power > > thanks > |
Help Stop running this script Msg | Network & Sharing | |||
| Can't stop Winmail from running at startup | Vista mail | |||
| How to stop searchprotocolhost running? | Vista General | |||
| processes don't stop running | Vista performance & maintenance | |||
| Program Stop Running | General Discussion | |||
