Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Hibernate and Restart problem
Old 09-09-2008   #1 (permalink)
Ristar
Whenever I try to hibernate, the laptop would take a while... which it's
fine, 'cos it isn't exactly top of the line, since its for college use only.
However, instead of hibernating (eventually), it restarts.
What's the problem and is there a solution to this?
In addition, whenever there's an orphan/zombie process running, the computer
just *won't* restart, even if i told it to. And from the looks of another
thread i posted, which is about killing that kinda processes, it does not
seem like there's a way to.
Is there any other way to restart the system (since I just can't kill the
affected processes), other than killing LSA or shutting off the power?
Old 09-10-2008   #2 (permalink)
Ramesh Kumar MVP
Re: Hibernate and Restart problem
First of all update your BIOS and drivers and
try this: 'Visit Here' (http://tinyurl.com/5cuoxq)
Ramesh Kumar MVP
RAMESH KUMAR
Microsoft MVP: 'My MVP Profile'
(https://mvp.support.microsoft.com/profile/Ramesh.Kumar)
My Blog: 'It's My Windows' (http://itsmywindows.com)
Ramesh Kumar MVP's Profile: http://winvistaclub.com/forum/member.php?userid=17
View this thread: http://winvistaclub.com/forum/showthread.php?t=21830
Missing shutdown, restart, hibernate and sleep in start menu General Discussion
Hibernate Problem Vista General
User Accounts, Switch User, Hibernate, Sleep, Restart Vista account administration
Hibernate problem Vista General
Problem with Hibernate Vista General
