| Vista Home Premium 32bit | How to remove $RECYCLE.BIN and System Volume Information Hi, Can anybody tell me how to remove a $RECYCLE.BIN and System Volume Information folders from my drive D i got these folders from an infected USB but now i cant remove them? please Help!! |
| | Re: How to remove $RECYCLE.BIN and System Volume Information No, you did not get these from 'an infected USB' since it is normal for them to be present on all fixed drives/partitions, and you cannot permanently remove them. And please stop shouting. -- Maxwell Bluemeanie "moonlight" <guest@xxxxxx-email.com> wrote in message news:a791b444aa16ab86fd065ee598d4c8c8@xxxxxx-gateway.com... Quote: > > HI, > CAN ANYBODY TELL ME HOW TO REMOVE A $RECYCLE.BIN AND SYSTEM VOLUME > INFORMATION FOLDERS FROM MY DRIVE D I GOT THESE FOLDERS FROM AN INFECTED > USB BUT NOW I CANT REMOVE THEM? PLEASE HELP!! > > > -- > moonlight > |
| Vista Home Premium 32bit | Re: How to remove $RECYCLE.BIN and System Volume Information wowo!! thanks for the reply! and bytheway was i shouting!!! ?well if its normal than y wasnt these folders present before when i used a clean USB. Now when i am sure that the USB had some threats and these folders appeared, u r saying its normal. i dont get u explain anyone? |
| Windows 7 RC x64 Vista HP x86 | Re: How to remove $RECYCLE.BIN and System Volume Information These files are normally Hidden System Files - It would appear that some how you have made them visible. Check on Organize - Folder and Search Options - View Tab and check the status of the Hide Hidden Operating system Files and the Hidden Files. As for the shouting - best to keep to the default font for posting ![]() |
| Vista Home Premium 32bit | Re: How to remove $RECYCLE.BIN and System Volume Information OH i c, thanks Nigel, i got it. |
| 43 GB System File in System Volume Information on 160 GB partition | Vista General | |||
| System Volume Information | Vista security | |||
| System Volume Information | Vista hardware & devices | |||
| Need to fix System Volume Information | Vista security | |||
| System Volume Information | Vista performance & maintenance | |||
