Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Go Back   Vista Forums > Vista Newsgroup Archive > Vista Newsgroups > Vista performance & maintenance
Vista - ...need help with Dreamweaver cs3/Vista Business
09-24-2008   #1 (permalink)
Windows Vista Ultimate 32-bit
Norway
I have tried to install Dreamweaver cs3 on my acer extensa 5620z, running Vista Business 32-bit. I do not get any wrong messages during the installation - all is sucessfully installed. Every time I try to open the program after the installation, it stops at the "initialiazing". I have also tried "selective startup mode" before installing Dreamweaver, but with no luck... Photoshop, Illustrator and Flash CS3 runs normal...I can not figured out what to do... so, PLEASE ANYONE..OUT THERE!!
CAN YOU HELP ME??
09-25-2008   #2 (permalink)
Carey Frisch [MVP]
Re: ...need help with Dreamweaver cs3/Vista Business
Installing Dreamweaver CS3 in Selective Startup Mode on Windows Vista
http://kb.adobe.com/selfservice/view...nalId=kb401454
"jagprint" <guest@xxxxxx-email.com> wrote in message
news:0e6ae5c10eb6b13ecf93e3bedb7cada6@xxxxxx-gateway.com...
> CAN YOU HELP ME??
> jagprint
11-15-2008   #3 (permalink)
vista home premium 32bit
i too have this problem & tried the selective startup solution and still no luck - i cannot understand this because it installed on my laptop just fine!
my partner needs this programme but hates using the laptop, so please somebody help.
thanks
11-30-2008   #4 (permalink)
Norway
Hello!
I have now found a soloution regarding this problem. Everytime you try to install or re-install Dreamweaver (or other programs) there are some files that not will be deleted in the registry on your laptop. Of course you can use a registry-cleaner such as CC-cleaner and so on - maybe this helps for you, but this is what I have done: I have done a complete pc upgrade to vista ultimate. The first program that I re-installed after the upgrade was Dreamweaver...YES - quite a job, but now I have no problems at all with this or other programs...
I hope this can be helpful!
 ...need help with Dreamweaver cs3/Vista Business problems?
Similar topics to: ...need help with Dreamweaver cs3/Vista Business
Photoshop CS3 & Dreamweaver CS3 work on Vista X64 SP1? Software
Will Dreamweaver CS3 slow down my 32-bit Vista Software
Vista won't delete Dreamweaver Vista General
Old versions of Photoshop and Dreamweaver in Vista Vista General
Dreamweaver and Vista problem Vista General
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
