Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista Tutorial - Need help with reinstalling system files such as shell
Old 09-28-2008   #1 (permalink)
Newbie
Vista Home Premium
So I made an error with my PC...
It started it when I restarted my PC and a popup keeps coming up saying that something like "Cannot detect the shell23 fiel. Re-installing it would help"
And nothing shows up but a blank black screen--I can't even access my documents or files or anything! Other things such as "Task Manager" popped up saying that it stopped working.
I also tried restoring those files with the USB but like I said, no windows would open. Just...a big fat black screen staring back at me.
Help ?
Old 09-28-2008   #2 (permalink)
1337 spammer
Windows 7 RC
Re: Need help with reinstalling system files such as shell
Quote  Quote: Originally Posted by Sifi View Post
Help ?
Welcome to the Vista Forums
I'd suggest starting with repairing the system files. There are also links to other repairs as well:
System Files - SFC Command
Let us know if that works for you.
Old 09-28-2008   #3 (permalink)
Newbie
Vista Home Premium
Thanks!
I'm currently looking at the "How To Perform a Repair Installation For Vista" page and my Vista was already installed onto my PC when I bought it; so I'm assuming that I must go purchase it? ><
Also, the pop-up actually said about my SHELL32.dll file--it also stated to reinstall that but of course, is that referring to a disc?
I did not receive any sort of a CD when I bought the PC. -__-
Old 09-28-2008   #4 (permalink)
Master
Vista Ultimate 64bit SP2/
What kind of pc do you have.
Old 09-28-2008   #5 (permalink)
Newbie
Vista Home Premium
Quote  Quote: Originally Posted by mansrm81 View Post
what kind of pc do you have.
hp.
Old 09-28-2008   #6 (permalink)
Master
Have you made the Recovery Disc's
Old 09-28-2008   #7 (permalink)
Newbie
Vista Home Premium
Unfortunately, no...
Old 09-28-2008   #8 (permalink)
Master
You can get them from HP's website only have to pay shipping and handling. What kind of HP computer do you have like the model?
Can parent shell monitor run/crash status of Child shell/exe ? PowerShell
Problem with Power Shell and .config Files PowerShell
How to run power shell in batch files or MS-DOS PowerShell
Reinstalling the system recovery files made just before system rec Vista installation & setup
Wrap command shell in System.Diagnostics.Process PowerShell
