Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Reliability Monitor System Stability
LinkBack Thread Tools Display Modes
Old 10-07-2008   #1 (permalink)
ahmed.khacef-orleans.fr
Guest
Hi, my Reliability Monitor System Stability Chart stopped updating on
september 1, 2008.
I've checked Task Schedular and RACAgent is still running: Status is
Queued; Last Run Result is "Unspecified error (0x8007000D).
I do what Clay propose. After running RACAgent.exe , no file in C:
\ProgramData\Microsoft\RAC\PublishedData and one file "RACREPCATALOG"
in the StateData directory.
HELP !!!
Thanks, Djouabi
Old 10-07-2008   #2 (permalink)
Brink's Avatar
Administrator
Vista x64 Ultimate SP2
Re: Reliability Monitor System Stability
Hello Djouabi,
You might see if running a "sfc /scannow" (no quotes) command can find and fix any bad system files that may be causing this. This tutorial will show you how to if needed.
System Files - SFC Command
View Post
september 1, 2008.
HELP !!!
Thanks, Djouabi
Old 11-07-2008   #3 (permalink)
Johan
Guest
I got the same error, tried also what's proposed on
Reliability Monitor no longer adding new data,
but doesn't change anything, also tried the sfc/scannow command, which
doesn't find any problems...
"Brink" wrote:
Quote:
> Hello Djouabi,
> Hope this helps,
> Shawn
> ahmed.khacef-orleans.fr;854897 Wrote:
> > september 1, 2008.
> > HELP !!!
> > Thanks, Djouabi
> Brink
> *There are no dumb questions, just the people that do not ask
> them.*
> '*VISTA FORUMS*' (http://www.vistax64.com)
> *Please post feedback to help others.*
Old 11-07-2008   #4 (permalink)
Brink's Avatar
Administrator
Johan,
Since those did not help, you can try a System Restore using a restore point dated before this problem if available.
System Restore - How to
If that does not help, then doing a Repair (upgrade) install may.
Repair Install For Vista
Quote:
Johan
View Post
"Brink" wrote:
Quote:
> Hello Djouabi,
> Hope this helps,
> Shawn
> > september 1, 2008.
> > HELP !!!
> > Thanks, Djouabi
> Brink
> them.*
Old 11-07-2008   #5 (permalink)
Johan
Guest
System restore, replacing an image,... is not really an option for me, too
much effort for this one function (it's the only problem I currently have,
and I don't really look forward to reinstall all my programs) Thx for your
quick reply anyway... If someone else knows how to fix this without much
hassle?
Johan
"Brink" wrote:
Quote:
> Johan,
> Hope this helps,
> Shawn
> > "Brink" wrote:
Quote:
> > > > Hello Djouabi,
> > > find
> > > > Hope this helps,
> > > > Shawn
> > > > ahmed.khacef-orleans.fr;854897 Wrote:> > > > >
> > > > on
> > > > > > september 1, 2008.
> > > > is
> > > > "RACREPCATALOG"
> > > > > > HELP !!!
> > > > > > Thanks, Djouabi> > > >
> > > > Brink
> > > > them.*
> Brink
> them.*
> '*Windows 7 Forums*'
> (http://www.sevenforums.com/) *and* '*::Vista Forums::*'
Old 11-18-2008   #6 (permalink)
Newbie
Vista Home Premium 32bit
I have the same problem, I have try all the suggestions above. I have try restore system point and it doesn’t help either.
Have anybody find a solution?
Please help us!!
Old 11-18-2008   #7 (permalink)
Brink's Avatar
Administrator
Quote:
Foppa
View Post
Please help us!!
Hello Foppa,
You can try a Repair (upgrade) install.
Display Modes
Reliability Monitor Mark Vista General 3 04-20-2008 07:12 PM
Preformance Monitor is this ok?Sys Stability Chart EndlessSacrifice Vista General 3 02-07-2008 09:09 AM
New version of the compatibility, reliability, and stability update for Windows Vista z3r010 Vista News 5 10-27-2007 12:33 AM
New version of the compatibility, reliability, and stability update for Windows Vista Tie Various Vista General 7 10-24-2007 10:52 AM
Reliability Monitor Alexander Burton Vista performance & maintenance 9 12-29-2006 04:55 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
