Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - How to repair corrupt COM+ Catalog on Vista without System resto
Old 11-12-2008   #1 (permalink)
Ivan Fioravanti
On my Vista PC COM+ catalog is corrupted, on XP and Windows 2003
reinstallation of COM+ is possible with sysoc.inf modification on XP and
simple Add/Remove Windows Components on Windows 2003.
I tried everything on Vista, but it seems thata there is no way to repair a
broken COM+ catalog apart from System Restore.
Is there someone that can give me an hint and save me from a sure
reinstallation from scratch ?
Old 01-07-2009   #2 (permalink)
islogi
RE: How to repair corrupt COM+ Catalog on Vista without System resto
Hi Ivan
I am also having the same problem....cant see any solution for this anywhere.
Please advice
"Ivan Fioravanti" wrote:
Quote:
> Hi,
is any software can repair and restore corrupt and miss files in windows vista Vista General
Vista: How to repair corrupt System files -- Avast Antivirus Vista performance & maintenance
Re: Corrupt Catalog CBS 0x800B0100 Vista performance & maintenance
AIK System Image Manager (SIM) spontaneously reboots while generating catalog file Vista installation & setup
Cannot create catalog file in System Image Manager (SIM) Vista installation & setup
