Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - vista not displaying problem and reports control panel
Old 12-08-2008   #1 (permalink)
32 bit vista home premium
Anyone help as I do not want to do a full re-install if I dont need to.
When using my main/admin account, I cannot display the problem and reports control panel (wercon.exe). The UAC panel comes up, after pressing continue, nothing happens. If I use another account on the laptop then it does displays it.
I cant find an error message anywhere to help me. I have checked services, and its set to started/AUTO. I did notice in the perfmon (I think) that it said the wercon.exe was stopped, but no idea how to restart from there. I checked services again and it still showed started. I tried a system restore x 3 but to no avail. I am now passed my technical knowledge, can anyone help please.
Running Vista 32 Home premium SP1
Norton Protection Centre
Windows Defender
Thanks for your co-operation
Nobby
Windows Vista Home Premium Ed., Control Panel will not open problem. Any suggestions for fix? Vista performance & maintenance
HELP - Vista Control Panel problem + other strange things Vista General
Vista Control Panel Problem Vista General
"problem reports and solutions" control panel does not launch Vista performance & maintenance
Vista RTM Control Panel Problem Vista General
