Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - monitor going to sleep
Old 12-21-2008   #11 (permalink)
Mike Hall - MVP
Re: monitor going to sleep
"emanddd" <guest@xxxxxx-email.com> wrote in message
news:7b23f8991be3cbd3b113aa4605713463@xxxxxx-gateway.com...
Quote:
> If the light on the back of the power supply lights up does that mean
> the power supply is good? how do I test the motherboard and find what
> motherboard i need? is there a way to look it up online, i have a compaq
> sr5214x. thanks
> emanddd
It is not the most precise of tests, but the brightness of the LED on the
front panel is an indication that the PS is not delivering too well..
Mike Hall - MVP
How to construct a good post..
http://dts-l.com/goodpost.htm
How to use the Microsoft Product Support Newsgroups..
http://support.microsoft.com/default...help&style=toc
Mike's Window - My Blog..
http://msmvps.com/blogs/mikehall/default.aspx
Old 12-22-2008   #12 (permalink)
Chuck
The first thing to do is to disconnect the monitor cable from the P/C with
power to the monitor and P/C OFF!
Then apply power to the monitor Only, with the interface cable from the
monitor to the P/C disconnected (usually at the P/C.)
Most working monitors will show some sign of activity, and may display
something that basically indicates that the monitor is not getting an input
signal. You may be able to enter a setup mode that displays information
concerning the current monitor settings from a button on the monitor control
panel.
(Divide and Conquer!)
news:377300005f8d9701b9732c3be6d1374f@xxxxxx-gateway.com...
Quote:
> my kids have a Compaq running vista home basic. we have had this
> computer for over a year but has not been connected to the internet
> until two weeks ago. now the monitor went to sleep and we can't wake it.
> there are no lights on the keyboard and we get no response at all. i
> have read all kids of posts about this problem but most involve changing
> settings or updating drivers, we can't do any of that because i can't
> get any response. any help would be greatly appreciated. thanks
> emanddd
Old 12-22-2008   #13 (permalink)
Chuck
And, depending upon the P/C, flickering may indicate HD activity. Without
knowing what was typical for a particuliar P/C before it started to have
problems, light indications are not too useful.
"Mike Hall - MVP" <mikehall@xxxxxx_mvps.com> wrote in message
news:uEWIDw8YJHA.4456@xxxxxx
>> sr5214x. thanks
>> emanddd
> Mike Hall - MVP
Old 12-22-2008   #14 (permalink)
MGJ
I have the same problem periodically with a year old HP Media Center PC; I
can't
find a pattern except perhaps that the computer sometimes loses connection
with the wireless keyboard and mouse so moving the mouse fails to wake up
the computer.
It seems to relate to certain programs, such as Windows Mail, left open when
Windows goes to sleep.
In my case, it is not the monitor which you can check by turning it on and
off - you should get a brief manufacturer's or other power on message.
I wouldn't be too quick to replace the computer, just double check the
"power" settings and close programs down before going away from it for a
while - that solved my problem.
> emanddd
Old 12-22-2008   #15 (permalink)
Mike Hall - MVP
"Chuck" <cdkuder@xxxxxx> wrote in message
news:%23jYDhTAZJHA.6108@xxxxxx
>>> sr5214x. thanks
>>> emanddd
>> Mike Hall - MVP
I wasn't talking about flickering at all. Over the years, I have noticed
that failing power supplies struggle to maintain brightness of the power
LED..
Mike Hall - MVP
Old 12-22-2008   #16 (permalink)
vista home basic
when i turn just the monitor on a box comes up that says "no input signal" then a different box comes up and says "monitor going to sleep" then the screen goes black
Old 12-22-2008   #17 (permalink)
Mike Hall - MVP
news:2c9f2c7c8dbeb6a72d39bb28500c30ee@xxxxxx-gateway.com...
> emanddd
They all do that. It shows that there is no video output from the tower..
You need to try a different power supply first as that is the cheapest
option..
If there is still no life in the machine, you are looking to replace
expensive bits..
Mike Hall - MVP
Old 12-22-2008   #18 (permalink)
Richie Hardwick
"Mike Hall - MVP" <mikehall@xxxxxx_mvps.com> wrote:
>option..
I don't know if matters have changed over the years but not that many
years ago it was practically impossible to find a replacement power
supply for a Compaq machine. Nothing available in the normal market
would fit in the box.
Richie Hardwick
Old 12-22-2008   #19 (permalink)
Mike Hall - MVP
"Richie Hardwick" <richiehardwick@xxxxxx> wrote in message
news:3u50l45elarr8c0as43g8r9nl6fh3l7f4s@xxxxxx
>>option..
> Richie Hardwick
Yes, a case change may be required as well..
Mike Hall - MVP
Old 12-22-2008   #20 (permalink)
Richie Hardwick
>>>option..
>> Richie Hardwick
I don't think you've ever been inside a Compaq computer. Everything
used to be proprietary, including the mobo. Nothing but the hard drive
was replaceable.
Richie Hardwick
Monitor can't go to sleep Vista General
monitor won't come out of sleep Vista General
Re: Monitor won't sleep Vista hardware & devices
monitor sleep mode General Discussion
4 screens on one monitor and monitor won't wake up from sleep mode Vista hardware & devices
