| | #21 (permalink) |
| | Re: monitor going to sleep "Richie Hardwick" <richiehardwick@xxxxxx> wrote in message news:6tk0l4dj7g07fa183jj0mh57lnnq2shr4s@xxxxxx Quote: > "Mike Hall - MVP" <mikehall@xxxxxx_mvps.com> wrote: > Quote: >>"Richie Hardwick" <richiehardwick@xxxxxx> wrote in message >>news:3u50l45elarr8c0as43g8r9nl6fh3l7f4s@xxxxxx Quote: >>> "Mike Hall - MVP" <mikehall@xxxxxx_mvps.com> wrote: >>> >>>>You need to try a different power supply first as that is the cheapest >>>>option.. >>> >>> I don't know if matters have changed over the years but not that many >>> years ago it was practically impossible to find a replacement power >>> supply for a Compaq machine. Nothing available in the normal market >>> would fit in the box. >>> >>> Richie Hardwick >> >>Yes, a case change may be required as well.. > I don't think you've ever been inside a Compaq computer. Everything > used to be proprietary, including the mobo. Nothing but the hard drive > was replaceable. > > Richie Hardwick I think you will find that is not the case anymore, and hasn't been for a while.. -- Mike Hall - MVP How to construct a good post.. http://dts-l.com/goodpost.htm How to use the Microsoft Product Support Newsgroups.. http://support.microsoft.com/default...help&style=toc Mike's Window - My Blog.. http://msmvps.com/blogs/mikehall/default.aspx |
| Monitor can't go to sleep | Vista General | |||
| monitor won't come out of sleep | Vista General | |||
| Re: Monitor won't sleep | Vista hardware & devices | |||
| monitor sleep mode | General Discussion | |||
| 4 screens on one monitor and monitor won't wake up from sleep mode | Vista hardware & devices | |||
