| | Yikes! Help! Chkdsk ran, now can't launch apps except thru Help li Hello everyone, This is almost fruitlessly complicated, but I'm not making this up. I'm about to reinstall rather than deal, but I would just love some help trying to understand whay may have just happened here. Here's the sequence of events in a nutshell: 1. BSODed twice in two days, and once about three weeks ago, all with the same symptom of a disk activity light frozen "on" before I had to do a hard reboot. The associated error this time is: KERNEL_DATA_INPAGE_ERROR / NTFS.sys / 0x0000007A. I remember seeing the kernel error before. From what I understand, this is one of a number of things: a) CPU overheating; b) power distribution; c) RAM; d) HDD problem of some sort; e) Corrupt pagefile; f) MBR MALWARE. 2. I have a multiple partition setup, which seems to be creating a lot of problems along the way: a) No kernel dump. I have settings for a kernel dump, but there seems to be an undocumented constraint in Vista that prevents it from writing a kernel dump to a non-C pagefile. (My pagefile has been set to D so it doesn't eat space on C.) b) When I ran CHKDSK, I can only get a log in Event Viewer for the last partition it checked. The other partitions' logs are missing -- perhaps overwritten! (Yet another "undocumented" constraint?) 3. After running CHKDSK, I can no longer launch any apps at all. (Some of those apps are on non-C partitions.) I can't even launch standalone apps not written to the registry and not on the C drive! The only way I've been able to get into IE7 is by using the hyperlinks in Windows Help. (Is that indicating anything?) 4. CPU -- Can't check the core temp because I can't launch an app to do so, but it wasn't above 60 last time. 5. LAPTOP POWER DISTRIBUTION is a total mystery to me. No idea how to check that. POWER SUPPLY seems OK. After all, if the power were on the blink, I wouldn't see the HDD light stay lit during the crash. I did have to do a lot of RAM swapping lately to RMA some low-latency RAM that had aggressive and problematic preset timings. There's a chance I fried something, but I tried to take all the necessary precautions against static or against ruining contacts. 6. RAM: Memtest has given me no errors on the memory itself. 7. HDDs: It's my sense that the BSODs have ONLY occurred when I have had a recently-acquired, 2ndary HDD installed in my ThinkPad's PATA<->SATA swappable bay. The SMART scans look clean for both of my HDDs, and the HDD activity that froze was in all likelihood not related to the new HDD, but to the primary, older HDD. If there's an HDD problem, I assume to would have to do with a setting-related conflict, not with the physical hardware itself. 8. PAGEFILE: The initial BSODs could easily have had to do with pagefile corruption. In the last two cases, the freeze has occurred during a very memory-intensive IE session. (The last one was actually just after waking from sleep to restore a heavy IE session.) The pagefile is NOT at its full capacity, however. And there were no corrupt sectors on either disc before I ran checkdisk. 9. MBR MALWARE: This is a possibility, but I ran a full system scan after the first BSOD, and came up with nothing. I also ran anti-spyware, anti-trojans, and anti-rootkits. All nil. If there's something there, it's totally hidden! That said, I have also not been able to get Windows Update to install any Windows hotfixes since July. (KB352709 is the hotfix that's holding everything else up.) I just went through everything with MS Update tech support, and they concluded it was a Vista problem. I'm now working with Vista tech support, and they're recommending a reinstallation-in-place. That's the next step, but as this "organ failure" stage was triggered by CHKDSK, I'm wondering what on earth is happening now! I'm including the Event Viewer ERRORS, WARNINGS & CHKDSK LOG I got since the reboot after CHKDSK: Any guesses or help would be DEEPLY appreciated! ERRORS The Software Licensing service failed to start. hr=0xD000026E, [2, 4] Windows Defender scan has encountered an error and terminated. Scan ID: {2BBF4F2B-9239-4A3A-AF51-473ADDCDA5D6} Scan Type: AntiSpyware Scan Parameters: Quick Scan User: NT AUTHORITY\NETWORK SERVICE Error Code: 0x8050800d Error description: Some history items could not be displayed. Please wait a few minutes and try again. If that doesn't work, clear the history and then try again. \??\C:\Windows\SysWow64\DRIVERS\nxsIO32.sys has been blocked from loading due to incompatibility with this system. Please contact your software vendor for a compatible version of the driver. The Access Connections Main Service service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion. A timeout was reached (30000 milliseconds) while waiting for the Access Connections Main Service service to connect. The description for Event ID 7023 from source Service Control Manager cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. If the event originated on another computer, the display information had to be saved with the event. The following information was included with the event: Software Licensing %%3489661550 The resource loader failed to find MUI file The following boot-start or system-start driver(s) failed to load: TVicPort Unable to initialize the security package Kerberos for server side authentication. The data field contains the error number. _________ WARNINGS File System Filter 'luafv' (Version 6.0, 1/19/2008 12:59:06 AM) failed to attach to volume '\Device\HarddiskVolume6'. The filter returned a non-standard final status of 0xc0000369. This filter and/or its supporting applications should handle this condition. If this condition persists, contact the vendor. _________ CHKDSK LOG FOR ONE OF THE THREE PARTITIONS Chkdsk was executed in read/write mode. Checking file system on M: Volume label is "Apps 1 (Primary HD OSes)". 256 file records processed. 0 large file records processed. 0 bad file records processed. 0 EA records processed. 0 reparse records processed. 368 index entries processed. 0 unindexed files processed. 256 security descriptors processed. Cleaning up 9 unused index entries from index $SII of file 0x9. Cleaning up 9 unused index entries from index $SDH of file 0x9. Cleaning up 9 unused security descriptors. 56 data files processed. CHKDSK is verifying file data (stage 4 of 5)... 240 files processed. File data verification completed. CHKDSK is verifying free space (stage 5 of 5)... 4070982 free clusters processed. Free space verification is complete. Windows has checked the file system and found no problems. 16383999 KB total disk space. 33308 KB in 59 files. 52 KB in 58 indexes. 66707 KB in use by the system. 65536 KB occupied by the log file. 16283932 KB available on disk. 4096 bytes in each allocation unit. |
| Vista Ultimate X64 SP2 | Re: Yikes! Help! Chkdsk ran, now can't launch apps except thru Help li Disk is fine. Sounds like your issue is Windows File corruption possible due to malware/registry cleaners- I would reformat drive and reinstall Windows. |
| Launch 2 apps simultaniously | General Discussion | |||
| Yikes, 119 degrees C | Overclocking & Cooling | |||
| Start Menu Fails to Launch Certain Apps | Vista performance & maintenance | |||
| Bitlocker & chkdsk & offline defrag apps | Vista security | |||
| Renamed Guest Account - Yikes! | Vista account administration | |||
