| Vista Ultimate x64 | HELP...Identify processes running and... I need help identifying processes running and how to shut them down so that I can free up memory...I have anywhere from 80 to +90 processes running. I have 2gb memory and 80%-90% is always being used? I have like 12-16 svchost running and have no idea what they are. I scan my entire cpu every night with AVG and win def...It says I have a clean computer. |
| | Re: HELP...Identify processes running and... Viracocha711 wrote: Quote: > > I need help identifying processes running and how to shut them down so > that I can free up memory...I have anywhere from 80 to +90 processes > running. I have 2gb memory and 80%-90% is always being used? I have like > 12-16 svchost running and have no idea what they are. > > I scan my entire cpu every night with AVG and win def...It says I have > a clean computer. from www.malwarebytes.org. Then if the machine is clean, do clean-boot troubleshooting to determine what is running. To identify things you see, Google the process name. How to troubleshoot a problem by performing a clean boot in Windows Vista - http://support.microsoft.com/default...b;EN-US;929135 Using the System Configuration Utility: Start Orb>Search box>type: msconfig and when it appears in the Results box above, right-click and choose "Run as Administrator". If you are prompted for an administrator password or for a confirmation, type the password, or click Continue. Then see what is on the Startup tab. You don't need to restart immediately, but the next time you do you'll get a dialog saying you've used the Utility. Usually in Vista this will be blocked by Windows Defender and you'll need to allow it so you can then tick the box that says in effect, "don't bother me about this again". Important - Do not use the System Configuration Utility to stop processes. Instead, use Services. Start Orb>Search box>type: services and when it appears in the Results box above, right-click and choose "Run As Administrator". Confirm elevation as needed. The free Autoruns program is very useful for managing your Startup - http://www.microsoft.com/technet/sys...s/default.mspx - Autoruns Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ |
| Vista Ultimate x64 | Re: HELP...Identify processes running and... Is there a good free (I will pay if it is worth it) program that a novice could use to safely identify and control what processes are running? I know there has to be way to many running on my machine that do not need to be. 85-95 processes at any given time? I downloaded auto-runs however, I am not confident I know which programs to remove from the start-up. I know I sound ignorant, and I am, but I do want to learn...Anyway, any tips for using AutoRuns would be greatly appreciated! |
| Vista Home Premium 32bit | Re: HELP...Identify processes running and... yes. process scanner. google is your friend and also lighten up. 80-90+ processes. WOW i have 39 -50 at MOST go to start-run-type msconfig- see start up tab- click on it- there u will see what starts up when u boot up also go type black viper services or Windows Vista Service Pack 1 Service Configurations by Black Viper if u have vista with sp1 have fun!! disclamer. i am not responsible for system crashes or any harmful events |
| Vista Ultimate x64 | Re: HELP...Identify processes running and... yes. process scanner. google is your friend and also lighten up. 80-90+ processes. WOW i have 39 -50 at MOST go to start-run-type msconfig- see start up tab- click on it- there u will see what starts up when u boot up also go type black viper services or Windows Vista Service Pack 1 Service Configurations by Black Viper if u have vista with sp1 have fun!! disclamer. i am not responsible for system crashes or any harmful events ?????"and also lighten up. 80-90+ processes. WOW i have 39 -50 at MOST" I am not a computer expert...I know I have to many processes running. I need a way of IDENTIFYING what each process is and then a way of shutting them off so that they do not automatically start? I am going to the website "Black Viper" and see if I can figure something out...??????????????????????????????????????? |
| | #6 (permalink) |
| | Re: HELP...Identify processes running and... On Mon, 2 Feb 2009 11:20:32 -0600, Viracocha711 <guest@xxxxxx-email.com> wrote: Quote: >I am not a computer expert...I know I have to many processes running. I >need a way of IDENTIFYING what each process is and then a way of >shutting them off so that they do not automatically start? find out what it is. Much of what you see is probably something proprietary to your computer. Quote: > >I am going to the website "Black Viper" and see if I can figure >something out...??????????????????????????????????????? T A K E Y O U R T I M E ! ! ! DDW -- Reply via this group No email please |
| | #7 (permalink) |
| Vista Home Premium 32bit | Re: HELP...Identify processes running and... try to keep at minuimin i have 3 start up programs |
| | #8 (permalink) |
| Vista Ultimate x64 | Re: HELP...Identify processes running and... Thanks! |
| | #9 (permalink) |
| Vista Home Premium 32bit | Re: HELP...Identify processes running and... also. try to lower some service's. and disable UAC services such as parental controll. if u dont use it then disable it or set it on manual also look for brinks tutorial for faster preformance and boot up |
| 80+Running processes and 50%+ physical memory | Vista General | |||
| Comparing running processes | Vista General | |||
| processes don't stop running | Vista performance & maintenance | |||
| Vista64 has 59 running processes.... | Vista General | |||
| running multiple processes in background | PowerShell | |||
