Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Vista 64 will not load
Old 02-03-2009   #1 (permalink)
Vista Ultimate 64
Hello,
I recently rebuilt my desktop with an ASUS P5Q motherboard with a recent Ameritrends BIOS version, Intel Q9550 chip, Sapphire Radeon 4870X2, and 2x2GB Corsair PC 8500 memory. I used my Vista Ultimate 64 from the original hard drive and it reactivated properly and the system worked fine for approximately two weeks. Two days ago, after playing Doom 3 for an hour or so, I exited the game and shut the system down normally. Yesterday when I attempted to start up, Vista would not go beyond the Green bar - it stalls with a blank screen. Neither will it load in any form of safe mode, and it will not load from the original DVD.
I had resident on a separate hard drive Windows XP 64, and I am able to boot up the computer by changing the boot order in my BIOS. Once booted with XP 64 I can see the drive with explorer, and disk management reports that the drive with Vista 64 is "healthy." However, one other data drive is showing "offline" and I have been prompted to reformat it, which I have not done. I have updated and run AVAST and Spybot, but no attempt to load Vista 64 has been successful. I would certainly appreciate any help.
Aubrey Mills
Old 02-03-2009   #2 (permalink)
DL
Re: Vista 64 will not load
Posting in all caps renders your post too hard to read
"Aubri452" <guest@xxxxxx-email.com> wrote in message
news:f5fae6ca70c70d5eff2174d8dde4e2fd@xxxxxx-gateway.com...
Quote:
> HELLO,
> I RECENTLY REBUILT MY DESKTOP WITH AN ASUS P5Q MOTHERBOARD WITH A
> RECENT AMERITRENDS BIOS VERSION, INTEL Q9550 CHIP, SAPPHIRE RADEON
> 4870X2, AND 2X2GB CORSAIR PC 8500 MEMORY. I USED MY VISTA ULTIMATE 64
> FROM THE ORIGINAL HARD DRIVE AND IT REACTIVATED PROPERLY AND THE SYSTEM
> WORKED FINE FOR APPROXIMATELY TWO WEEKS. TWO DAYS AGO, AFTER PLAYING
> DOOM 3 FOR AN HOUR OR SO, I EXITED THE GAME AND SHUT THE SYSTEM DOWN
> NORMALLY. YESTERDAY WHEN I ATTEMPTED TO START UP, VISTA WOULD NOT GO
> BEYOND THE GREEN BAR - IT STALLS WITH A BLANK SCREEN. NEITHER WILL IT
> LOAD IN ANY FORM OF SAFE MODE, AND IT WILL NOT LOAD FROM THE ORIGINAL
> DVD.
> I HAD RESIDENT ON A SEPARATE HARD DRIVE WINDOWS XP 64, AND I AM ABLE TO
> BOOT UP THE COMPUTER BY CHANGING THE BOOT ORDER IN MY BIOS. ONCE BOOTED
> WITH XP 64 I CAN SEE THE DRIVE WITH EXPLORER, AND DISK MANAGEMENT
> REPORTS THAT THE DRIVE WITH VISTA 64 IS \"HEALTHY.\" HOWEVER, ONE OTHER
> DATA DRIVE IS SHOWING \"OFFLINE\" AND I HAVE BEEN PROMPTED TO REFORMAT
> IT, WHICH I HAVE NOT DONE. I HAVE UPDATED AND RUN AVAST AND SPYBOT, BUT
> NO ATTEMPT TO LOAD VISTA 64 HAS BEEN SUCCESSFUL. I WOULD CERTAINLY
> APPRECIATE ANY HELP.
> AUBREY MILLS
> Aubri452
Old 02-03-2009   #3 (permalink)
Vista Ultimate 64
I have no idea why the text presented itself in ALL CAPS. It was typed without any shouting and it appears without caps in the forum.
Quote  Quote: Originally Posted by DL View Post
Quote:
> HELLO,
> DVD.
> AUBREY MILLS
> Aubri452
Old 02-04-2009   #4 (permalink)
Vista Ultimate 64
Hello,
Yesterday I tried once again to load Vista 64 from the DVD. After approximately one and one half hours it did load. From there I was able to use the various tools to restore everything except the hard drive that crashed. I speculate that that that hard drive crash somehow threw Vista off its stride. Although I am still running through a few tests and defragmenting, etc., Vista seems to be back and I can replace the failed hard drive. Thaks.
Aubrey Mills
Quote  Quote: Originally Posted by Aubri452 View Post
Quote:
> HELLO,
> DVD.
> AUBREY MILLS
> Aubri452
Old 02-05-2009   #5 (permalink)
Ultimate x64
to be honest... I would be careful building my own computer and trying this x64 lol... I am realizing there still are so many things not working properly here... I would say you are lucky with how it went
Old 02-05-2009   #6 (permalink)
Vista Ultimate 64
Hi Lakmilis,
I agree. Even though it was pesky, it could have been much worse. At present, the system seems to be working within normal limits for everything except the failed hard drive. I am lucky there too, as I had backed up the data recently. I have set restore points and I am soon expecting to acquire the Acronix True image software to keep things in hand, I hope. Of course, there I lots of things going on in Vista 64 that I do not pretend to understand, but that seems to be the way of the world. Thanks for your input.
Quote  Quote: Originally Posted by lakmilis View Post
Old 02-12-2009   #7 (permalink)
Vista Home Premium 64 bit
I have the same problem as Aubrey Doom 3 installs but will not run. No Problems with Call of Duty 4 or running Steam games.
Checked around the internet and found no solution.
I tried Loading it on Mint-6 64 Linux
using the native linux version and it WORKED!! It's a streamlined version of Ubuntu .
Why don't you play the native linux installer ? You don't have to buy it, just download the linux installer and copy some of the game files from the cd to the harddrive
. Enjoy
Windows Update Won't Load--gets error-"This page failed to load" Windows Updates
Vista Won't Load/HD won't allow other HDs to load General Discussion
Does the XMLDocument.Load(System.IO.Stream) method load the whole .NET General
cannot load vista Vista installation & setup
Vista RC1 will not load Vista General
