Go Back   Vista Forums > Vista Newsgroups > Vista performance & maintenance
Vista - Display start up problems
Old 02-04-2009   #1 (permalink)
Teresa
Hi, I've only had my Dell inspirion D530s,Windows Vista, for two months and
it's doing the same thing, I have to turn it on and off about 6 -10 times to
get windows to come up, I just get a black screen with the Dell logo and
also the keyboard won't turn on. I've been have'n problems with downloading
and and timing out! I went into the device manager, and clicked on Network
Connection, clicked Properties and then went through all the tabs running
Diagnostic tests, I found I had : Ping Gateway 70.67.73.1 : Failed, Ping DNS
64.59.160.13 Failed, : Ping DNS 64.59.160.15 Failed, also there was a
yellow triangle with an exclamation mark in it and it said ; NO WINS server
is available for this connection. Then there was another :Ping Network
70.67.73.255 Failed. After that was the Links section and it said:
Could not reliably detect speed and duplex settings. Possible speed/duplex
settings are 10 Mbps Half duplex and 10 Mbps Full Duplex.
Everything else on the computer says it's running just fine, all lights are
working as they should, this is very frustrating because I looked up the
problems on the Microsoft web and it says there are many things that can
cause connection problems and its really hard to determine which! But it
sounds like your having same problems as I, so maybe we can work together on
this! I've heard a few other people having this sort of problem with their
Dell and Dell isn't any help at all!
Teresa
Old 02-04-2009   #2 (permalink)
DL
Re: Display start up problems
Its under warranty, phone Dell
"Teresa " <tlasman@xxxxxx> wrote in message
news:OdKU6jqhJHA.1388@xxxxxx
> and it's doing the same thing, I have to turn it on and off about 6 -10
> times to get windows to come up, I just get a black screen with the Dell
> logo and also the keyboard won't turn on. I've been have'n problems with
> downloading and and timing out! I went into the device manager, and
> clicked on Network Connection, clicked Properties and then went through
> all the tabs running Diagnostic tests, I found I had : Ping Gateway
> 70.67.73.1 : Failed, Ping DNS 64.59.160.13 Failed, : Ping DNS
> 64.59.160.15 Failed, also there was a yellow triangle with an exclamation
> mark in it and it said ; NO WINS server is available for this connection.
> Then there was another :Ping Network 70.67.73.255 Failed. After that was
> are working as they should, this is very frustrating because I looked up
> the problems on the Microsoft web and it says there are many things that
> can cause connection problems and its really hard to determine which! But
> it sounds like your having same problems as I, so maybe we can work
> together on this! I've heard a few other people having this sort of
> problem with their Dell and Dell isn't any help at all!
> Teresa
Desktop Display/UPDATE, WON'T START, HELP PLEASE : ) Vista hardware & devices
Recent Programs won't display on Start Menu Vista General
Display problems at start up - Screen blank Vista General
Start Menu Search Box Results Display Vista file management
Weirdest problems.Can't start programs from start menu and use Cop Vista General
