| | How do I make 64 bit IE my default so IE links "will" respond I have a Dell Studio 1737 with Vista x64. Vista defaults to IE 32. Many links from IE and Windows Mail will freeze (not responding) with the default. I have found multiple sites that discuss this problem but none of then details a way to fix this. The nearest suggested Control Panel-Defaults but EI 64 was not shown as an option. A 2007 posting requested MS to fix this. Doesn't look lake they did. Does anyone have a solution? |
| | Re: How do I make 64 bit IE my default so IE links "will" respond Hi, Snowman. Are you sure? Most complaints are in the opposite direction, saying that Flash and some other applications won't work with 64-bit IE. Can you give us some examples of links that won't respond with 32-bit IE? Any specific filename extensions that require 64-bit IE? I'm not aware of any. It's easy enough to make 64-bit IE the default on your own computer. Just change any shortcuts or icons to point to the iexplore.exe in Program Files, rather than the default "Program Files (x86)". I've left 32-bit IE the default on my Start menu, but have also created a shortcut for 64-bit IE and pinned that to the Start menu, too, naming it "IE8 beta - 64-bit". RC -- R. C. White, CPA San Marcos, TX rc@xxxxxx Microsoft Windows MVP (Running Windows Live Mail 2009 in Win7 Ultimate x64 7000) "Snowman" <Snowman@xxxxxx> wrote in message news:383B1B8E-320F-4323-914E-20BFE0B6BD59@xxxxxx Quote: > I have a Dell Studio 1737 with Vista x64. Vista defaults to IE 32. Many > links > from IE and Windows Mail will freeze (not responding) with the default. I > have found multiple sites that discuss this problem but none of then > details > a way to fix this. The nearest suggested Control Panel-Defaults but EI 64 > was > not shown as an option. A 2007 posting requested MS to fix this. Doesn't > look > lake they did. > > Does anyone have a solution? |
| How do I make "Rich Text" the default | Live Mail | |||
| Vista Photo Gallery, make "actual size" the default | Vista music pictures video | |||
| "Run as Administrator" ... make default?? | Vista General | |||
| Change links under "Favorite Links" in Windows Explorer pane? | Vista General | |||
| How do you make "more information" the default when copying files | Vista General | |||
