1.    10 Apr 2009 #1
    Josh Roig Guest
    HKEY_LOCAL_MACHINE problem
    I run Registry Mechanic and get the two identical messages:
    High Priority: Highlighted value is missing or invalid:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
    Search\Gather\Windows\SystemIndex
    I select the repair option, then restart the computer, run Registry Mechanic
    again, and get the same two messages.
    I have tried using the system restore option, trying all of my oldest
    existing restore points, and I get the message that an unspecified error has
    occurred and that the system files have not changed.
    The big problem is that my system has become pretty slow. Restarts often
    bring up an OS failure, although the automatic repair function takes the
    computer back to the same slow performing system.
    Does anyone have any suggestions?
    Thanks.
  2.    12 Apr 2009 #2
    Josh Roig Guest
    Re: HKEY_LOCAL_MACHINE problem
    "Bruce Chambers" <bchambers@xxxxxx> wrote in message
    news:enl74JguJHA.1208@xxxxxx
    >> Mechanic again, and get the same two messages.
    >> has occurred and that the system files have not changed.
    >> Thanks.
    > First and foremost: Stop sabotaging your system by using a snake oil
    > registry "cleaner" to damage it.
    > Then, try telling us precisely what problems you're having, under what
    > precise circumstances they occur, along with the exact text of any and all
    > error messages.
    > Generically, a slow down in system performance can be caused by having too
    > many unnecessary processes and/or applications running in the background,
    > malware, a badly fragmented hard drive, and/or too little system resources
    > (CPU power, RAM, etc.) for what you're trying to do. The one thing that
    > won't cause a system to slow down is the only thing you've mistakenly and
    > potentially disastrously tried to address: the alleged presence of
    > extraneous registry entries.
    Thanks for your advice. I've uninstalled Reg Mechanic (and also Ascentive
    Performance). There has been some improvement in speed.
    My program list includes the following:
    CCleaner
    RegCure
    PCSpeedScanPro
    I don't think I've used these for a long time. Should I uninstall them
    anyway?
    What can I do to speed up my system?
    Thanks.
  3.    13 Apr 2009 #3
    Malke Guest
    > CCleaner
    > RegCure
    > PCSpeedScanPro
    > anyway?
    Uninstall RegCure and PCSpeedScanPro. CCleaner is very useful although you
    should *not* use the registry cleaning function.
    The above indicates a possible hardware issue and you should do some
    hardware troubleshooting, starting with the hard drive and the power
    supply.
    http://www.elephantboycomputers.com/...ardware_Tshoot
    Software can cause slowness as Bruce already told you. Malware, too many
    processes/programs running in the background, etc. After you've determined
    that the hardware is healthy (or replaced the faulty components), scan for
    malware and do general maintenance.
    http://www.elephantboycomputers.com/...moving_Malware
    http://aumha.org/a/loads.htm - What loads at Startup?
    http://www.theeldergeek.com/services_guide.htm
    http://www.blackviper.com
    http://www.elephantboycomputers.com/...ml#Maintenance
    http://www3.telus.net/dandemar/slowcom.htm
    http://aumha.org/a/health.htm - Take Out the Trash
    Malke
    MS-MVP
    Elephant Boy Computers - Don't Panic!
    http://www.elephantboycomputers.com/#FAQ
No rights on HKEY_Local_Machine registry map 'optionalcomponents'
Can't remove or update several programs. Everytime I try the proces stops halfway removing or installing with the following error message: Can't...
Vista General
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Lsa
Apologies for re-posting this question - it got berried on the thread that I had attached it too. Any assistance greatly appreciated. I need to...
Vista General
Hkey_local_machine\components
I recently notice this key under HKLM,name is COMPONENTS Is it legitimate key for Vista? And for what is this key? Vista 32-bit SP1 (scaned...
Vista General
HKEY_LOCAL_MACHINE\BCD00000000 ?
I see a registry key I don't recognize at HKEY_LOCAL_MACHINE, it's value is BCD00000000. There are a few folders underneath but they don't seem to...
Vista General
app data in HKEY_LOCAL_MACHINE
Hell, I write an app that stores data for all users into the HKEY_LOCAL_MACHINE\Software\... path. In Vista, somehow the data is stored but not...
Vista security
hkey_local_machine\system\currentcontrolset\control\update
Does Vista still support this branch because I cannot get it to load my nt style policy file? This is the same setting that poledit modifies so you...
Vista account administration
Vista Upgrade Problem - Windows Explorer Loop problem
I have a Motion 1400. I upgraded to Vista using the Microsoft DVD. I did not use the full install. Vista comes up but is hung up on searching...
Vista installation & setup
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
